Thread: Temp sensor
    Temp sensor
    The water temp sensor on my Intellitouch will not re-calibrate to current temp. I checked connections. It reverts back to old setting after I change the temp and press
    the menu button. Any suggestions?
    Thanks
    Roy
    14,500 gal pool
    Inground
    Intellichlor Salt Generator
    Water Fall
    Re: Temp sensor
    Those sensors can go bad sometimes, which means replacing them.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Temp sensor
    What he said, I had to change one on my roof for my solar heat after less than 6 months of use as it was reading over 10 degrees off
