Thread: Pool installation gone bad
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Can you please post a picture of your out of level pool installation that is still functional?
    I would like to see how bad you can go with the installation
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Re: Pool installation gone bad
    Any above ground pool more than 1" out of level is at risk of collapsing. The pool may well stand up for weeks when it is out of level, but then collapse later. Pool collapse can be quite dangerous, I wouldn't risk it.
    Pysiek's Avatar
    Apr 2012
    419
    It's not that I want to do it that way. I'm just curious who did it and how does it handle it
    May 2014
    Corona, CA
    21
    My pool is a round Pro Series metal frame 14'x 42". After getting the pool set up I found that one side is about 2 1/2" higher than the other. I under stand that this is probably the max of out of level I should be and probably should have emptied and re-leveled. I totally would have if this was a large pool and would have kids being crazy in it. It is just my and my gf using it to keep cool during the summer and will take it down in a couple months. So far the pool shows no bad signs and of course of it does I will empty it.
