Results 1 to 10 of 10
Thread: hard plumbing and the HASA Chlorinator installed
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    I have finally got the hard plumbing and the HASA Chlorinator installed. I plumbed the skimmer first. Waited to make sure I had no leaks. Then I plumbed the return side and added a second suction side inlet. I added an extension at ground level (lower left of photo) so I can extend the plumbing further around the pool so I can add a second return. I'm hoping the added circulation will help keep the steps clear of debris and algae.
    Today I added the Hasa Chlorinator. I think I'll call her Chloe. Went in like a dream. I loaded a few gallons of pool chlorine and turned it all on. I'll check the chlorine in the morning to see if it's working and to fine tune the output. Please keep your fingers crossed for me.
    Oh, and the cute guy with the concerned expression is Dave. He's my pool boy and works his little behind off so I don't have to.
    We took our first swim of the year this past weekend. It was wonderful! Air temps in the low 90's and water temp about 80 degrees. I thought it was going to stay cold for forever! Sure am happy that things warmed up. Though, in about a month I'll be hating the heat and humidity. Still though, I'll have the pool to keep cool in! YAY!
    I can only add three photos at a time so I'll need to add a couple in a separate post.
    Oh, I have a question for anyone else with the HASA Chlorinator. Am I supposed to watch the level of the float in the flow indicator or am I supposed to watch the water level in the flow indicator? Thank you to anybody that can answer my question,
    Pool boy Dave.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: hard plumbing and the HASA Chlorinator installed
    Great job... Nice and tidy... Looks awesome...
    Just one little thing! If you don't cover or protect that chlorine it will degrade quickly in direct sunlight... Many people cover their liquidators with cardboard boxes covered in packing tape to try to weather proof it a little, but you want to cover it....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thanks lacygirl. I've looked and couldn't find how people were covering it. Currently I have a pop up canopy over the whole equipment pad and I've put the HASA on the east side of the filter so only morning sun gets to it. I will be covering the unit itself now tho. Thanks a bunch. My husband and I are toying with the idea of coating it with white rubberized paint. If it works, great, if not it will peel off.
    Angie M.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Hi Taterfink... Here's the link I was reading.... http://www.troublefreepool.com/threa...liveable/page3
    I wanted to go with the liquidator, but postage costs from the US to Australia made this item way out of the price range.... I was lucky enough to find a brand new Stenner pump right here in Australia, so I went with the cheaper option...
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thank you for the link. When I was researching, I missed that one. I've heard of the Stenner but don't really know what it is or how it works. Is it a tank of chlorine and a pump to feed to the pool? Do you like it? I liked the idea of the liquidator (assuming it works for me) partly because it doesn't use electricity. My electric company already loves me far too much for me to willingly give them more money.
    Angie M.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Oh great! Now I want one too! Sparklypoolitis is getting expensive for me...all the money I'm going to save on chemicals is going to be spent on "stuff"!
    Time to do some research! BTW Your plumbing looks great!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thanks! You're correct, pool store savings have been spent on new pump, filter, liquidator, Dave the Diver (my pool boy), deck, deck furniture and privacy fence. I'm hoping that at some point I can stop saving so much money. 😂
    Angie M.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Hi Taterfink and Beens... The pump itself is very simple, it sucks bleach or other various liquids directly through a tube that is compressed to cause suction... Clever little thing because the liquid doesn't pass through the pump itself, so no corrosion, just tube replacements.... I managed to pick up my Stenner here in Australia online for $100... It was too cheap to leave it there... You just put your bleach in a big container and the peristaltic pump can be set to a timer to deliver the amount of bleach you need to your pool... Very simple... I got one primarily to stop me destroying T-shirts when I feed the pool... I have a tendency to spill and splash it....lol... There's heaps of vids on youtube, https://www.youtube.com/watch?v=UCLdSKBS6Yk
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thanks!
    Angie M.
    Apr 2013
    NC
    65
    Looks great! I sent a PM (I think I only sent one...ugh...might have sent another before I was done )
    ~ Green as algae, but willin' to learn! ~
    ~26' Intex Ultra Frame Pool - finally leveled!
    ~approx. 17,000 gal
    ~2,500gph pump w/ cart. filters~Taylor K-2005 test kit
