Thread: Is PH of 7.8 too high?
    Mar 2014
    Orlando, FL
    35
    My PH seems to creep up to 7.8 and then remains fairly steady -- just wondering if I can leave it here provided I keep close watch.
    Also, my CH is slowly trending downwards - It has gone from 275 to 225 in a month -- I suspect this is because my fill water is after whole house water softener. How low is too low before I need to raise it? (Pebbletec)
    Latest Numbers:
    Ph - 7.8
    FC - 5
    CC - 0
    CH - 225
    TA - 70
    CYA - 70
    Salt - 3600
    Temp - 80
    15k gal, Pebbltec. Built in 2004. 2 HP Pump, Cartridge Filter, Hayward SWG, Hayward Navigator Cleaner, TF-100 / Orlando, Florida
    38,299
    Re: Is PH of 7.8 too high?
    That pH is fine, especially with the CH on the lower end. you may not want to let it get too much lower. The CSI in PoolMath can give you an idea of how low is too low.
    May 2014
    DFW
    27
    I'm in pretty much the same boat you are. My Ph gets to 7.8 and will hold there for along time. My water is also softened so I keep some calhypo around to maintain CH around 250 (also have pebbletec) and so far so good
    30,421
    Or, you can simply look at the limits in "ABC's of Pool water chemistry" in Pool School. It will tell you and should be required reading for every member of TFP. Calculating CSI is not necessary.
