Thread: I need to redo my Liquidator!... I seem to recall a parts list to retrofit things...
    Question I need to redo my Liquidator!... I seem to recall a parts list to retrofit things...
    I've had it with the crappy check valves, float gauge and the rest of it (I did buy a new Watts valve that is a "push on" type... not sure about it...)... I'd like to redo things and have some questions...
    What was the benefit of using the thicker hose and fittings?
    Is there a parts list (I seem to recall there being one?)...
    And... just to be sure... should there *ever* be air in the float gauge or should it always be 100% full of water?
    Thanks! It's been almost 2 years, I love the Liquidator... but I think I'm "ready" to have it just the way I want it!
    Pete
    16000 Gal. Kidney / Gunite / SE Florida / Taylor K2006 / Stenner
    Jandy CS100 / Sta-Rite U3 Skimmer / Pentair Great White / Single Floor Drain / Single Return / Hayward SP2300VSP
    I'm still learning and I know nothing!.. I'm loving the Stenner!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: I need to redo my Liquidator!... I seem to recall a parts list to retrofit things
    http://www.troublefreepool.com/threa...increase-flow)
    US Plastics ships quickly.
    The flow meter just gets new adapters with the upgrade. I don't believe anyone has found a suitable replacement for it.
    The meter will always have a little empty space in it above the ball.
    Ha! I didn't know it... I already have 3/8" line... so I just need to change up some parts for hopefully better quality ones...
    Question:
    Something seems to have changed (or perhaps I'm remembering it wrong)...
    When my pump would shut off the ball would drop to zero.
    Now, when my pump shuts off the ball stays around "2" until the water level in the Liquidator reaches the bottom of the outlet.
    What gives?
    mine does the same thing occasionally--- no problem though
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
