Thread: Cleaning Cell in SWG
    I have a chlor-ease swg. what can I use to clean the cell. I am having problems with no chlorine in the pool. I have shocked and it was good for about 3 days then back to 0. I need some help trying anything and everything before sending it back for then to evaluate the swg to see if it is a manufacture defect, they say it will take 3 weeks to do this. Thank You for any help you guys can give me. Latest readings salt at 3700 TH 0, TC 1, FC 1, Ph 7.6, TA 80, CYA 50. Thanks again.
    ktdave's Avatar
    Katy, TX
    888
    Re: Cleaning Cell in SWG
    Hi donna,
    One thing that jumps out at me is that your CYA (stabilizer) level is a bit low contrary to ChlorEASE recommendation. They say that 80 ppm is optimum and you are at 50 ppm. I have attached the instruction manual if you see that a cleaning is necessary. For most SWG's a 4 parts water to 1 part muratic acid solution is recommended, but inspect your cell first to see if you have any scale deposits and adjust your CYA to recommended level, otherwise it may just be a defective unit.
    Attached Files Attached Files
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    I would bet money Dave's right. SWG's are REALLY particular about the CYA level. Mine doesn't seem to make Chlorine at 50 CYA either.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Jun 2008
    Tennessee
    12
    I have a friend who is having the same problem. The "pool store" is telling her that the cya level is 65 and she has no chlorine. They instructed to shock the pool with granular shock and placed her name on the service call list. Can she just add bleach instead of granular shock? I know zero about a SWCG so I didn't know what to tell her, but I knew you guys would know the answer.
    20 x40 IG vinyl pool
    When FC goes to zero with a SWG it is a good idea to shock the pool (in addition to checking the SWG is working, and that PH, CYA, and salt levels are appropriate). While you can use any form of chlorine, bleach is the best choice in most cases.
