Thread: Strange CC reading
    Infinity8's Avatar
    May 2014
    Florida
    2
    Strange CC reading
    Recently I brought my free chlorine level to around 18 PPM to rid my pool of a high combined chlorine reading. After two days of keeping the level at 18 PPM I went to test the CC again with my Taylor k-2006 kit, when I got to the point where I used R-0003 the water turns pink/red for about five seconds and then turns a green color. Does this mean that CC is present in the pool or not?
    Re: Strange CC reading
    Welcome to TFP!
    I've never heard of a FAS-DPD test turning green. I suspect you may have had something contaminating the test. I recommend trying the test again and see if it works correctly this time.
    Infinity8's Avatar
    May 2014
    Florida
    2
    Thanks for the welcome!
    I've done the test twice now while the pump was running from both the spa and the actual pool. I will try to do it again but with my free chlorine being this high I will be running out of R-0871 quickly.
    When there is no CC present it does not turn pink at all? Even for a second when adding R-0003?
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Nope, it won't turn pink. I almost never have cc's!
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
