Thread: Aqua PLUS AQL-PLUS Trouble
    May 2014
    Douglas
    1
    Hello, started opening my pool and am having a problem with the AQL Panel.
    When I provide power to the panel the display back light comes on and I do not see any thing (No Display)
    The Red Check System light and the Green Pool/Spa light (One to the left) flash 6 times in a long pulse pattern and then 4 very fast flashes.
    If I attempt to hit the filter button the filter will power on and off three times real fast and then power on, and the display just goes blank.
    This is the case for the light as well.
    occasionally the display will come on and the system will act as though it is operating correctly and I can see all of the display functions, but then it just stops working.
    My thoughts are that the control board is bad or the main PCB. Is there a way to better diagnose this problem?
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Re: Aqua PLUS AQL-PLUS Trouble
    I have the same system and have called hayward a few times with questions. Their customer service is excellent and I'm sure they can tell you really quick what's going a on. The customer service number is on their website.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
