Results 1 to 16 of 16
Thread: Pool capacity
    Aug 2013
    Brighton, MI
    62
    Pool capacity
    I'm not sure if this is the correct place to post this, but the math savvy probably hang around in here.
    I'm over shooting a bit on my calculations and I think the pool size is wrong. Original owners say 36k. I figured 32500 or so.
    I came across a diagram so I wonder if someone smarter than me could take a stab at it. Thanks!
    20 x 40 28k gallon Salt Water Vinyl IGP, Hayward pump and Sand filter
    Aug 2013
    Brighton, MI
    62
    Re: Pool capacity
    Ack.. There is a little difference... at the deep end they added a curve... A Roman something or other. It goes about another 4 ft. My guess is it was added as an option to this base style.
    Re: Pool capacity
    I get something around 27,000 gallons, though I am not completely sure how to adjust for the "deep end they added a curve".
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pool capacity
    I think the deep end of the pool (short edge), they mean there is a circle arc making the deep end longer.
    Like this:
    Isolated Spa - 345 Gallons
    Re: Pool capacity
    I did some very quick math (40 in * 40 feet * 20 feet * 1.33 in gallons) and got 26.5 K gallons. I just treated it as a box ignoring the deep end, then added 33% more on for that. No way is it 36K.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
    Aug 2013
    Brighton, MI
    62
    Re: Pool capacity
    It is 8 ft deep in the deep end but the strange thing is I measured 8.5 feet from water surface to bottom. Maybe with the Roman end they added a diving board and more depth. But yes the curve looks like the one posted.
    Thanks for your attempts!
    Aug 2013
    Brighton, MI
    62
    Re: Pool capacity
    Perhaps i can test with chlorine? Add 128 oz of 12.5 and measure the change? What's the earliest i can test after adding to get an accurate result
    38,301
    Re: Pool capacity
    You can test after 30 minutes or so, but chlorine may not be a good indicator.
    Re: Pool capacity
    The most reliable approach is to track the expected vs actual change in levels across a number of different chemical additions, and continue adjusting your proposed volume to minimize the overall error across all of them. There is too much potential testing error in a single addition to get very good results.
    May 2014
    Billings, MT
    4
    Re: Pool capacity
    I came up with 33,000
    shallow end= 800
    two slopes=2016
    deep end= 1600
    this adds up to 4416
    times 7.48 and we get 33,031
    You would need a curve half the size of the shallow end to make it 36k.
    20,000, Inground, Vinyl, Hayward 24in sand filter, Hayward super pump, Hayward heater 250,000
    Aug 2013
    Brighton, MI
    62
    Re: Pool capacity
    Makes sense. So for now I should start by reducing my volume from 32 to 28 k for the calculator... given the initial results here?
    Re: Pool capacity
    Good plan. Then track how your actual results differ from your calculated results from there.
    Aug 2013
    Brighton, MI
    62
    Re: Pool capacity
    Quote Originally Posted by dagoat1967 View Post
    shallow end= 800
    two slopes=2016
    deep end= 1600
    Must have crossed posts because I missed yours when I replied last. The curve doesn't seem to be half the size, but I'll take a pic and see what you think.
    Aug 2013
    Brighton, MI
    62
    Re: Pool capacity
    Here is a pic.
    Ellington, CT
    262
    Re: Pool capacity
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Aug 2013
    Brighton, MI
    62
    Re: Pool capacity
    Thanks, that is useful.
