Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Backwash hose
    Backwash hose
    Hi all, stupid backwash hose question. We had gone through several cheap b/w hoses that Mr PB included (they always bust holes easily). Finally got a good one that has no issues, but it's only 25' and really need a 50 footer. Here is my issue. If I flatten the current hose, it measures 2.5" across. The pipe from the filter has a reducer fitting on the end which measures a 1.5" diameter. Sooooo, do I need a 1.5 or 2" hose (and have not seen any 2.5" ones, but the current one is 2.5 across (when flattened). It appears stretched perfectly over the end of the reducer, and not bunched up (as i would expect of a larger diameter hose clamped onto a smaller pipe). Of all the pool equipment stuff, never imagined this would be a difficult purchase!
    10k gallon fiberglass freeform pool, Paramount SwingJet system, Dolphin DX5 robot, Pentair 48" Tagelus sand filter with glass media, WhisperFlo 1 HP pump, Hayward H200FDN natural gas heater, TF-100 Test Kit, and, of course, Margaritaville Tahiti blender!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Backwash hose
    That's a 1.5" hose.
    Two sides at 2.5" across means a 5" circumference. π*diameter = circumference. Therefore, 5"/ π =1.59"
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: Backwash hose
    Welp,
    I went through something similar as you. I ended up getting myself a Firehose on eBay for less than 40 dollars. (A tip from someone on the forum tipped me off to the firehose gig.) There are tons of them there. Prolly will last forever.
    Edit: Richard already posted the size, so I just delete mine.
    Divin Dave,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Backwash hose
    Yes you can get out of service date fire hoses from fire cabinets cheap on ebay
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: Backwash hose
    Isaac, I think that well may have been you that gave me that firehose tip. The thang works fantastic. With my cartridge, I dont backwash, but I use it for pumping water to waste during toad strangler rain so I dont overflow. Using it tonight actually. Raining cats and dogs in N.E. Texas tonight.
    Divin Dave,
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Re: Backwash hose
    I hate those stupid roll up blue hoses. It's the main reason I had a dedicated hard backwash pipe installed out into the woods behind my yard.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Backwash hose
    Thinking of making a "soaker hose" for mine. Run it in river rock that surrounds pool deck or to the high side of my yard...
    Isolated Spa - 345 Gallons
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Backwash hose
    Divin Dave, I am watching it slowly approach me on the weather radar now. Maybe another hour or so before those colorful red and orange storms on the radar screen get here
    Ike
    Jun 2011
    Northern Maryland (near Delaware)
    170
    Re: Backwash hose
    I saw this thread and thinking a 1.5 inch fire hose be good for backwash. I have 1 1/2 hp pump and need to do a 100 foot run. Will that be enough to pump it? Also, how to adapt the hose fitting to the pump outlet. I think it is NPT. not sure.
    Thoughts/suggestions
    Thanks
    Thanks
    15'X30'X52" AGP AquaSports Grande Buttress Free (10,620 Gallons), Hayward Dreamline S190 W Zeobrite, 1.5 HP Hayward PowerFlo LX, AquaLuminator Light+ fountain attachment, Pool Rover, Tf-100 test kit, Speed Stir.
    Re: Backwash hose
    Hi all. Am resurrecting this post as I've finally had it with backwash hoses! Had been using the typical pool backwash hoses, but they ALWAYS break and spring leaks. For some time had used a pool vacuum hose with a clamp on it, but that has not separated at one end so I need to hold the hose on the end of the pvc pipe while my wife turns the system on/off. I need to make this a one man job! Have looked online at the firehouse option and am very intrigued. On the heels of the last post in this thread, how would one set this up? I assume I would need to glue on a female threaded pvc fitting so that the firehose could be threaded on?
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Re: Backwash hose
    Any chance of putting in a hard waste line and burying it? I had that done when my pool was installed and it was the best thing I did! It runs over 75' to the woods, but it's just so clean and easy...
    Oct 2016
    Virginia Beach
    15
    Re: Backwash hose
    Quote Originally Posted by steveg_nh View Post
    I thought about doing this as I want to bury a 4" PVC pipe with a pop up drain for my downspouts, which are close to the pump. I could easily plumb in a connection for the backwash line, but my only thought was that the DE might clog the pipe over time?
    20000 gallon/ Hayward Pro-grid DE6020/Taylor 2006/Hayward SWG
    Re: Backwash hose
    I have thought about that and would love to, but it would mean digging a 25-30' trench across my lawn out to the woods edge near the equipment, which could be done, but it would be just another project to add my already behind schedule list!
    Re: Backwash hose
    Hi. Anyone have any thoughts on connecting an old fire hose? I believe I have a 1.5" FNPT end on my backwash line. I suppose I could cut one end off the fire hose and connect with a clamp, but that's a bit of a pain to connect whenever I have to backwash and not sure if s clamp would hold it?
    Re: Backwash hose
    Anyone know what the psi is during backwash process? Am looking at the below discharge hose as an alternative to a fire hose (much less expensive), and connecting via an NPSM to NPT adapter to connect to our backwash hose pipe.
    https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
    May 2017
    Avon, CT
    98
    Re: Backwash hose
    Mine is normally between 10-15 psi in backwash so that hose should suffice. I just ordered this one... Are you sure you just need 1.5"? I needed 2"
    100 Inch Swimming Pool Filter Backwash Discharge Hose Inground Above | eBay
    16' x 34' Irregular IG vinyl, ~18K gal, Hayward S210T Sand Filter, Hayward 1HP Single Speed pump, AquaCal SQ125 Heat Pump, TF-100 Test
    Re: Backwash hose
    Hi. Thanks for the reply. Pretty sure the existing pipe is 1.5", but will check when I get home. We have blown through so many backwash hoses and the pressure even broke the end of a vacuum hose that I used to clamp onto the pipe. The link for the hose you sent looks great, since I can cut to length and I can just clamp it onto the discharge pipe instead of hunting for an adapter to connect to the one I was looking at. Assuming you haven't had any issues with tears, breaks, etc.?
    May 2017
    Avon, CT
    98
    Re: Backwash hose
    I just got it Monday and haven't even looked at it yet as I've been too busy. They also sell 25 and 50 foot lengths. I may or may not need all 100 feet I would like to get the discharge to my property line and the 25 foot one that came from my PB was not cutting it. My pipe end is also 1.5" and i needed the 2" to fit over it and I planned on just clamping to it. You may want to reconsider the 2" size as well. It is similarly reinforced like the one you are considering.
    Re: Backwash hose
    That's a good point on the sizing. My existing 1.5" pipe has a threaded end attached which eventually terminates in a plastic barb type end. Was going to clamp to that, but might be better clamping this 2" hose higher up on the pipe before the fittings.
  20. Back To Top    #20
    Re: Backwash hose
    Hi again. So here is the one I'm thinking of ordering. It looks to be very heavy duty (150 psi). And I'm thinking of doing the 2" and just clamp it to the 1.5" pipe and exiting connectors, hoping that works and doesn't blow off when I turn on the backwash process.
    hydromaxx 150 psi | eBay
