Thread: CH on 20ppm?
    todd.scallions's Avatar
    Apr 2010
    Bartlett, TN
    57
    CH on 20ppm?
    I see that it says CH doesn't really matter for vinyl liners but there is still a recommend range of 200 & 400ppm. I've tested pool water twice and tested the fill water and my CH readings are coming out at 20ppm. Is there any danger for having such a low CH reading? Is there any benefit to bringing it into the recommended range?
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
    38,524
    Re: CH on 20ppm?
    Where do you see a range of 200-400 for CH for vinyl pools?
    Even 0 is fine in a vinyl pool ... so I would not worry about it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: CH on 20ppm?
    Low CH can contribute to foaming. Other than that... who cares? If I were you, I'd crunch some numbers and see what the cost per FCppm is between bleach and Cal-hypo, and if it was cheaper, use some Cal-hypo. I got a flier in the mail, all those pucks and powders are on sale right now!
    Apr 2010
    Bartlett, TN
    57
    Re: CH on 20ppm?
    I've already read that it didn't matter for vinyl liners I was just wondering if it was normal for such extremely low CH readings. I just assumed that my water would be somewhere in that general range.
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
    Apr 2010
    Bartlett, TN
    57
    Re: CH on 20ppm?
    Maybe I should have worded it differently. I wasn't asking "hey will 20ppm damage my liner" i was asking is there any negative impact to having such a low reading water quality wise and is there any benefit to having a higher reading. So it only effects foaming and that's it. Thanks for the help.
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
