Thread: Pool Installation Underway
    May 2014
    Lewisville, TX
    29
    Decided on a small play pool for the kids. 75' perimeter with 5' maximum depth. Today they sprayed the gunite and IMMEDIATELY afterwards I got a brief, yet hard rain. I understand wetting the gunite will slow the cure process and likely make it stronger. However, what I have noticed that concerns me a little is this:
    1. The smooth finish on the bottom is gone where they brushed the bottom. The rain was hard enough to expose small pea gravel from the gunite.
    2. Some water has accumulated in the bottom of the pool.
    None of the walls, steps or benches show any signs of collapsing. The edge of the pool where the coping will go is now rough from the large raindrops. Anything I should be concerned about?
    Pics of construction process are here: http://1drv.ms/1mSTQeV
    38,354
    Re: Pool Installation Underway
    Welcome to TFP!!!
    Sounds to me that now the plaster and mortar will have a rougher surface to adhere to ... I do not think it sounds like a problem, but see what the builders say.
    May 2014
    Lewisville, TX
    29
    Those were my initial thoughts as well. Hoping for the best.
    Casey's Avatar
    SW PA
    10,450
    Your builder will take care of any issues that arise due to inclement weather. Good Luck with your build and keep the pics coming!
    Aug 2013
    Maryland
    93
    Rougher should be better for plaster
