Results 1 to 12 of 12
Thread: Pump basket lid stuck...am I crazy to....
    Apr 2014
    Phoenix, AZ
    52
    I'm a new pool owner and have been diligently cleaning, lubing o-rings, etc. Two weeks ago I cleaned out all of the baskets, cleaned off the o-ring, applied new lube, put the lid back on hand tight only.
    Now the **** thing won't come off. I've used two channel locks on each side wrenching away, hit it with a hammer, tried everything I could that I wasn't going to damage the pump. Won't move. Been trying for a week.
    My lid and o-ring were already in poor shape and I had already ordered them. Lid is here, o-ring should be here today or tomorrow. I don't want to beat on the pump any more, I'm afraid of breaking something. Would I be crazy to cut the lid off with a RotoZip?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Pump basket lid stuck...am I crazy to....
    What kind of lid? Does it have ears on the side, or a handle across the top? There was a picture here somewhere showing how someone used a spading fork as a wrench on the handle.
    Apr 2014
    Phoenix, AZ
    52
    This is the lid. I've thought about putting something together specifically to open it but haven't gotten around to it. I'm not sure if I could generate enough torque with something directly above the lid. A garden tiller I used to have may have done the trick but given the current stuckedness, I doubt it. Something to think about for the future, though.
    19K PebbleTec in-ground with spa, Hayward Super II pump, DE 60 series filter, T-15 SWG
    Water feature, Hayward Northstar pump
    Richard320's Avatar
    Jan 2010
    19,074
    If something like that won't do it, then you probably will have to cut.
    Apr 2014
    Phoenix, AZ
    52
    I did some digging through other "lid stuck" threads but don't recall seeing that. It's perfect. I'm not sure if I'll have the room to maneuver because of the plumbing but I'm certainly going to give that a try.
    Thanks for digging the pic up for me.
    30,432
    I have never had to loosen one but I would tap it pretty solid with a rubber mallet while applying the twisting motion needed to turn it.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    422
    I just un-stuck a very frozen or stuck on cover just like that last week.
    1. I used large channel lock pliers on one side with cloth covering the plastic
    and
    2. A rubber maillot on the other side
    So I was twisting and pounding at the same time on opposite ends if that makes sense.... and off it came slowly.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Apr 2014
    Phoenix, AZ
    52
    I didn't check back in to see the last two responses prior to taking the angle grinder to it. blakeusa - your solution may have worked but I'm not sure. I used channel locks on both sides and couldn't get it to budge. I found out the pump also isn't anchored to the pad - this new house is full of lovely surprises.
    It was a serious pain to get off, even after grinding some pie wedges out of the top of the lid. Because the threads run down into the pump housing I couldn't cut that, but I managed to break a chunk off and get it out. I did damage the steel ring that runs on the inside of the o-ring, but the seal appears to be solid.
    AND I DIDN'T OVERTIGHTEN IT!!!!
    Now about finding a 30 year old pitch fork....I'm hoping the new lid doesn't give me as much trouble. I'll find out in a week.
    Jul 2017
    NJ
    3
    I have the lid pictured on my 1hp pump basket. Sometimes I use a plastic tipped wood clamp to remove lid.
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    5,678
    Welcome!
    Be careful responding to really old threads. You might start a new one if you have a specific issue.
    Be sure you keep your gasket on the pump lid well lubed with Pool Lube.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa
    Pentair CCP240 Cartridge Filter with Pentair Intelliflo 3050VS Pump and Pentair HTR250 heater. IC40 SWG. EasyTouch 4. TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Marty
    Jul 2017
    NJ
    3
    I do have a specific issue, Stuck lid. It may be an old thread but it's same issue.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    If it's the same lid, it's a Hayward, and they make a tool for opening the lid.IMG_0284.jpgIMG_0285.jpgIMG_0286.jpg
    chiefwej
