Results 1 to 17 of 17
Thread: Stenner pump suggestions?
    Does anyone have an opinion on which stenner pump is best? Im trying to send my PB some information so we can decide which to get but I am overwhelmed with the options. The econ series has a built in timer I think. Is this ideal or is there a better choice that requires a separate timer? He's ordering equipment today and wanted to order an intellichem but I don't like the price. So any guidance would be greatly appreciated!
    Thanks.
    Andrea
    35,000 gallon, IG pebble finish, cartridge filter, Pentair variable speed pump, Stenner chlorine pump, Dolphin Oasis Z5 cleaner, Spa, Slide and waterfall, construction complete June 1, 2014, TF-100 test kit, pool filled with Central Texas well water(very hard water)
    Re: Stenner pump suggestions?
    I have one of the classic series and have been very happy with it.
    Missouri City, TX
    73
    I have the Classic Fixed Output 10 gallon per day high pressure model:
    http://www.uswatersystems.com/system...sure-pump.html
    I have this plugged into an outlet that is on its own relay on our Hayward ProLogic 8 so I can set up a timer to run the pump anywhere from 20 minutes in the winter to about 45-60 minutes in the Summer each day.
    20,000 IG WetEdge Satin Matrix Northshore Plum, Filled 8/24/12
    So where do you get the timer and what brand or type do I get? Are you saying it can be set up with my intellitouch system? Will they know how to install it? Sorry I'm such a dummy about this stuff. :/
    Thank you!
    Aug 2011
    Southern California
    188
    I have my Stenner running through my EasyTouch as a program. I'm sure the Intellitouch can do the same.
    Jul 2011
    Northern NJ
    92
    Quote Originally Posted by alright_alright_alright View Post
    Thank you!
    Sent from my SCH-I545 using Tapatalk
    I'm thinking you could use an Intermatic timer as well.
    Anthony Pool, 35k gal plaster, DE (1.5hp Ultraflow), Rainbow 320, Dolphin Diagnostic 2001 (Advantage) & Polaris, Retrofitted Anthony mod #20 120v Niche light with Pentair 5G & adapter ring, 70's build / recoped and plastered 1.5 years ago
    Aug 2011
    Southern California
    188
    Quote Originally Posted by rickmnj View Post
    You could, but why would you when the Intellitouch has relays that can be programmed to turn on & off at certain times. It's just a matter of wiring the Stenner to that relay.
    Hopefully the OP has an open relay that is not being used.
    This is what I was curious about. I'm interpreting what you are saying Hawk as my intellitouch should act as my timer right? As long as the guy who installs my equipment knows how to do the wiring.
    So I should just need the pump and a storage tank? If I can figure out which ones now. Thank y'all!
    Aug 2011
    Southern California
    188
    Here is my thread from when I did mine- http://www.troublefreepool.com/threa...dated-1st-post
    It's been running great since day one. During the winter when chlorine needs are low, I just change the program to turn off at an earlier time (less minutes). During the summer I add more minutes. The Stenner pump I'm using has an adjustable head, but I leave it on #10 setting. When I hooked it up, I primed it, then ran it for 10 minutes. I measured out the chlorine and found it was pumping 1.75 ounces per minute. A bit different than what the manual says it should, but that's to be expected.
    This is great Hawk. Thank you so much!
    I assume voltage to be 120v right? Is 1/4" tubing adequate for a set up like Hawk's?
    Also, is a 30 gall tank overkill?
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    I think so, I find my 15 gallon will last close to 45 days even in the hot Arizona heat. You don't want to have it last too long because the clorine will loss it's percentages over time. 15 gallons is perfect.
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    Ok. My pool will be around 33.5k gallons. I guess I just thought I'd be using a lot of bleach. Lol. Thanks for your help.
    Aug 2011
    Southern California
    188
    During the summer, I inject mine at night and then let the pump run for two hours to disperse. That way it can sanitize without the sun burning it up right away. Then the pump comes back on about 6am for 6 more hours to finish cleaning before anyone gets the urge to get in.
    During the winter, I cut off the night time dosing and pump time and only dose at 6am just after the pump kicks on and finishes the priming sequence. That way it's up to full flow (Intelliflo VF pump).
    I was pleasantly surprised at how much less chlorine I use now with the Stenner. I no longer have any wide swings of free chlorine, everything is more consistent and predictable.
    Missouri City, TX
    73
    Yes, just like Hawk has mentioned, I have one spare relay on the ProLogic assigned to an outdoor outlet that I have the Stenner plugged into (yes on the 120V version). You can do the same with your Intellitouch also if you have the extra relay. Then just have a timer in the intellitouch that turns the outlet on or off at certain times (leave the stenner switched on at all times). Adjust the amount of time the pump is on to change the volume of chlorine added. (For the 10gallon per day pump = 0.89 oz / min)
    I have the 15 gallon tank as well.
    Thanks everybody! Parts ordered.
