Thread: Cleaning Pool Cover
    Mar 2013
    CT
    353
    Cleaning Pool Cover
    Can anyone suggest a SAFE/MILD cleaner to use on my in ground pool cover to clean it prior to putting it away.
    I need to lay the cover out on he lawn to clean it and I'm looking for something that won't harm the lawn when it drains through the mesh cover. I've seen pool cover cleaning agents at the pool store and Wal Mart but they seem pretty caustic from reading some of the Ingredients.
    Im wondering - should I just clean it when it's on the pool? And if so - with what?? I hate to put anything I don't need to in the water. Maybe use some diluted bleach and water? The cover is black though and I'm concerned it may affect the color.
    Thanks!
    Dan
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Casey's Avatar
    SW PA
    10,461
    Re: Cleaning Pool Cover
    Hey Dan. I have a solid cover for my above ground pool and to be honest with you, I will squirt a dab of Dawn with bleach in a bucket of hot water and take a broom and scrub the cover and then spray it off and leave it dry. I don't use a lot of soap, just enough to get the water soapy.
    I've had good luck with this: Natural Chemistry Spray-On Cover Cleaner http://www.doheny.com/poolsupplies/N...aner-5899.html
    Quote Originally Posted by dschribs View Post
    Thanks!
    Dan
    Kayak Pool - 12 ft. x 24 ft. rectangular, 5˝ ft. deep end
    Frog System, Sta-Rite-Modular Media Cartridge Filter, Pentair 1 H.P. pump
    AquaPRO Pro500 heat pump & Automatic AutoGuard™ Pool safety cover
    Dec 2009
    Virginia Beach, VA
    131
    I've got a mesh safety cover and I use my pressure washer with a fan tip. I just turn it down to a pressure that's just high enough to clean the crud (mostly pollen) off the cover but not high enough to damage the cover. It cleans it very well and WAY quicker than doing it by hand. Plus you're just using water so you don't have to worry about damaging the grass. Just make sure you don't turn the pressure up too high or you can really damage the cover. Start at the lowest setting and keep turning it up slowly until it cleans the cover. Start in the middle and work your way to the perimeter unless you can lay it out on a hill, then start from the top and work your way down.
    If you don't have a pressure washer, the method above is tried and true.
    30,000 Gallon Inground, Vinyl Liner
    DE Filter & Pentair IC40 SWG
    Pentair Legend Platinum w/ PB4 Booster
    Pentair Kreepy Krawler Prowler Robot
