Results 1 to 11 of 11
Thread: Aerator to raise PH (so I can lower TA)
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    I think this fits into this forum. Hope so.
    Anyway, my TA is around 120. I'd like to get it done to 70 or 80. I understand the process is to drop ph with acid (which also drops TA), and then aerate to raise ph so I don't touch TA. I read a few threads about building an aerator out of PVC, but have a few questions...
    1. I want to be sure I understand where an aerator is connected to. Nothing special is required right, you just remove the 'eyeball' from one of the return jets, and attach your aerator there?
    2. Using an aerator doesn't create any back pressure that is bad for the pump?
    3. Would something like this do the job as well? http://www.yourpoolhq.com/pool-aerator.html
    On #3, it's simple enough, and doesn't require me to make anything. And it's small enough that I won't worry about any tension on the threads/return port from a larger setup.
    thanks
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Aerator to raise PH (so I can lower TA)
    You understand correctly.
    If you just point one of your return eyeballs up so it churns up the surface of the water, you won't need to spend anything.
    120 TA is not too bad. Why are you lowering it? Do you have one of the two issues mentioned on the how-to article?
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Just trying to slow down ph rise. Seems like I have to add acid every two days. Unless that's normal. I wouldn't even know if I had a CSI issue easily, with a vinyl pool, would I?
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by steveg_nh View Post
    Sure you would. Just plug your numbers into Poolmath and scroll down to where it shows CSI.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Missed that down there!
    So mine says its -0.75. The section says:
    Less than -0.6 is suggestive of problems for plaster, tile, stone, and pebble pools.
    Greater than 0.6 is suggestive of problems for all pools.
    So -0.75 is less than -0.6. Assuming it's worded properly, I should reduce TA. Target in PoolMath showed as -0.99. Last time I checked. -0.99 is even LESS than -0.75. So my target would make it worse for me? I must not be understanding this right.
    30,432
    I sometimes hate that we ever put CSI on the table for discussion.
    If your pool stays within the parameters suggested in Pool School - ABC's of pool water chemistry, you will never have to calculate csi and never have to worry about it.
    My pool is about 8 years old and I have never considered csi nor has there ever been a need
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    So if I ignore that, how do I know if my ph buffering would benefit from a TA more in line with the recommended levels? I'm assuming it certainly can't hurt anything to get it in line.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,016
    There that thang is!!!!!
    Ive been looking for that thang for a couple of weeks and havent been able to find it again! That do dad works real nice. Friend of mine has one in his pool and I like the way it sprays water.
    I want one just for the sound of of the fountain and the 'ambience' when I need it!
    Thanks for the link!
    Divin Dave,
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    I can't use it without an adapter. It's only 3/4" threads.
    Lowering TA will reduce the rate at which PH increases dramatically .
    You read the comment in PoolMath about CSI incorrectly. It was telling you that vinyl pools are just fine with low CSI.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Thanks Jason. Sounds like I'll work on lowering the TA as planned then.
