Results 1 to 9 of 9
Thread: Hard Foam Insullation
    Apr 2014
    FOUR cORNERS
    111
    Hi Forum readers, I started to level back yard and install our intex pool(14 foot with 14" sand filter 3/4 h/p motor, more than enough for what we need, it really keep pool clean, I don't know where to add this to my signature yet but I will figure it out) properly after finding this sight (TFP) and seeing so many of your wonderful ideas, hard plumbing, I would have never of thought that this was possible,adding a through wall skimmer, cool. For years now we put up and take down put up and take down, you get the picture. Anyway, we've been taking pictures and I hope to put our project from beginning to end here, My question is I have really sandy soil which I think is good, I'm building a box frame around pool 14'6", we are going to put a layer of pea gravel then clean sand, gorilla pad and hard foam insulation, is that over kill for an intex? any comment would appreciated. Thanks
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Hard Foam Insullation
    Welcome to TFP.....No its not over kill for an intex... I'm doing pretty much the same thing.... One of the most important factors of a great above ground pool, is what's underneath it... You're giving the pool an excellent foundation, but you could probably loose the gorilla pad if you're using hard foam insulation... Don't use duct tape to tape the foam together, triple tape the seams with aluminium tape (that's what its called in Australia ...lol.. ) or something equivalent.... Enjoy building your pool, and make sure you order a test kit.... Perfect water needs to be tested and looked after like a pet...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Triple taping with Gorilla Tape is what has been suggested on here. I believe someone suggested water proof tape. I'm thinking that Gorilla Tape is water proof, suppose it'd be good idea to check the label.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    Feb 2013
    Yukon, Oklahoma
    220
    I would tell you duct tape is duct tape particularly when you will have a ton or so of water on top of it.....not much of any possibility of movement there.
    I agree with the pad not needed. Perhaps if you are going to continue to take the pool down every season it would help keep the foam boards cleaner if you put the pad under the foam. I wouldn't bother.
    Are you still planning on taking the pool down seasonally? If so you could still hard plumb and just put a few "unions" here and there to aid in that. The hard plumb made a world of difference on my Intex.
    May I recommend that if you are going through all the work of making a base for your pool that you may want a tarp (or something) to cover the exposed outside areas from washing away or being disturbed by heavy rainfalls (don't ask why, I think you already know why I am saying this...).
    Bob E.
    Apr 2014
    FOUR cORNERS
    111
    No we are planning to keep the pool up year round, just drain low enough as needed. Unions will be used to remove plumbing, One step I read is to use a tarp underneath liner. Is that a advised to do with foam??
    Apr 2014
    CT
    25
    I'm putting up a new AGP this spring and spoke with someone at the manufacturer - I asked him about using rigid foam instead of sand and he said it's a great idea. He recommended a gorilla pad on top of the foam, but his main reason was that with the weight of the water on the liner, you'll notice the seams, so his recommendation was really just to smooth out the bottom; not for technical reasons.
    Apr 2014
    CT
    26
    Anyone know... when putting down the hard foam insulation... does it need to be level with the bottom rails? I am thinking that when the area is leveled, bottom rail and wall assembled... then the sand is levelled and tamped... you are just above the bottom rail. Adding the insulation will raise that bottom an additional 3/4". Will that make a difference? or am I just over thinking this?
    Jun 2013
    Middlesex County/VA
    50
    I had my pool installed a few weeks ago. I have yet to get in the pool but can say it looks very smooth except for a few wrinkles and a few gaps. The gaps concern me but from other responses should not be a concern. The installers installed the foam before wall. I am sure this made for cutting to be easier. They then had to rework the wall as the skimmer was outta place. I believe that was to much direct weight and pressure on the foam. There was bno sand used. They leveled the area and then compacted. I would however recommend cutting your foam before wall but do not tape in place until after the wall was installed.
    Pool Size: 24' Lomart Whispering Wind II 13000 gallons
    Pool Type: Aboveground
    Pump:Hayward 1 1/2 HP Power Flo Matrix 2 Speed
    Filter: Hayward S230T 250lb Sand Filter
    Apr 2013
    Battle Creek, MI
    298
    Why the pea gravel? Excavate down to the lowest point, you're already on sandy soil, lay down the EPS foam and the "tarp" that comes with the Intex. The feet of my pool legs sit on top of the EPS, with the help of some 6"x6" ceramic tiles. No problems. And yes to the Gorilla Tape.
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
