Thread: calcium ring at water line
    I am wondering what the best way is to clean off the little bit of calcium ring that builds up at the water line on the vinyl liner. I'm using the BBB methods and I don't want to use anything too harsh. Thanks.
    27' AG w/deep center and main drains, 19,300 gal., cartridge filter, solar panel heater,
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: calcium ring at water line
    No advice people?
    Jul 2007
    Waterford Michigan
    36
    Would it be possable to get a set of test results? Without them it's dfficult.
    15x30 AG
    Cartridge Filter
    Solar Heater
    1.0 HP 2 Speed pump
    + 2 KIDS
    If you are sure it is calcium, then some diluted muriatic acid, four to six parts water to one part acid, should clean it up. Water test numbers would help us advise you how to reduce the chances of the same problem happening again.
