Thread: Caulking the joint between top of pool wall and bottom of coping stones
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    I was reading another member's thread on caulking the joint between the coping and his concrete deck. The recommendation was something poly based. I need to see if I'm ok with what my patio builder wants to use to caught the joint where my pool walls (vinyl liner) meet the bottom of the coping stones.
    This is narrow vertical joint, maybe only 1/8" wide. I've read a lot, and find references to elastomeric (what the builder is planning on using) and polyurethane, specifically, Vulkem 116. It was mentioned in another thread that poly is good, but the discussion was around the deck joints. There are lots of warnings on it about indoor use (not an issue of course) and potential cancer causing ingredients. I assume this is when wet, and not cured. But for this caulk line, which is only about 1/8" (except on the stairs where it's wider, and will have a backer bead behind the joint for support), is poly still the way to go? I don't want a mess when they do it. The builder says he uses this elastomeric and it's been fine.
    Any advice/discussion is appreciated.
    Thanks
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Re: Caulking the joint between top of pool wall and bottom of coping stones
    Just checking....any thoughts on this situation?
    Thanks.
    30,432
    Elastomeric is an adjective....not a product. All flexible caulk has elastomeric properties.
    I cannot quite picture where these joints occur. Can you post a pic?
    Even without the pic, I am virtually certain I would suggest polyurethane caulk. It just seems to have better flex and better resistance to aging.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    So to your point about "elastomeric" I just assumed he was talking latex, but maybe I should ask...This pic shows it best (although you still can't really see it)...but right under the coping rounded edge, where it meets the wall and sits on ti, that's the gap to caulk, just above where the lines slips into it's channel.
