Thread: Pool Store test results different from mine ....
    Apr 2014
    Lower NC
    134
    I had to get some sand and thought I would have them check the water. They show my CYA @ 68 and I get 50, they show my CC @ 3.64 and I get .75 - 1. Not sure if the difference is in their testing or mine, but I will keep up and SLAM as I am getting good results with the TFP method!
    13,500 gal, installed 2006, vinyl, 24' round, AG - sand filter, 1.5 hp pump, TF-100 test kit w/ SpeedStir
    Lower NC
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: Pool Store test results different from mine ....
    It's overwhelmingly more common that pool store results don't match home tests than that they do, and it's even common that pool store results don't match each other or themselves. Thread
    However, since I see a pool frog chlorinator listed in your equipment, I'd be suspicious of both readings. I'd expect to see CYA much higher.
    Casey's Avatar
    SW PA
    10,448
    If you're using the TF100 or K2006 you need to trust your test results.
    Apr 2014
    Lower NC
    134
    I have stopped feeding the frog, with the TFP method, I will keep slamming and watch as the water clears hourly!!!
    Lower NC
