Results 1 to 8 of 8
Thread: Removing print/ink from PVC pipe
    Mar 2013
    CT
    348
    I'm re-plumbing my PVC filter & pump this year with all new PVC. The lengths of straight PVC I bought from Home Depot are covered with red printing from the manufacturer as well as the bar code from Home Depot.
    Anyway to remove this printing from the pipe??
    Yeah, I'm pretty particular.
    Thanks!
    Dan
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Removing print/ink from PVC pipe
    Acetone or PVC cleaner will take it off. Better yet, paint the pipe to make it less visible.
    Aug 2011
    Southern California
    188
    Best to paint any exposed PVC pipe anyways. Prevent UV degradation.
    30,402
    While the surface does seem to "chalk" a little bit, I have used some 10 year old pvc that seems to be unaffected by UV. I'm not sure UV has much influence on pvc pipe.
    SW Indiana
    9,198
    Functionally, I doubt it is much of an issue at pool pressures. When I reworked my pool plumbing, I could tell the difference in the way the "old" pipe cut compared to the new. I don't worry about what is above ground, but I wouldn't bury pipe that had been exposed to UV for years. Mostly because I don't see the savings on pipe being worth the risk of having to dig.
    Aug 2011
    Southern California
    188
    When you get up to 20 and 30 years or more, as many pools do, you'll certainly see a difference.
    But I suppose, just like having a main drain versus not having, it will be debated for years...
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I agree with Hawk, when I replaced my solar heat plumbing last year I was shocked at how poor of condition the old PVC pipe was in, extremely brittle, glue joints that would pull apart, etc. Much of that old PVC pipe had never been painted and had been exposed to UV outdoors for over 20 years.
    30,402
    Well, we are certainly hi-jacking the thread a bit but it is an interesting topic...I found this.
    Testing and past field experience studies have concluded that when conventional Type I, Grade I (Cell Class 12454) rigid PVC pipe is exposed to UV radiation from sunlight the following conditions have been noted.
    - The effects of exposure to UV radiation results in a color change to the product, slight increase in tensile strength, slight increase in modulus of elasticity, and a slight decrease in impact strength.
    - UV degradation occurs only in the plastic material directly exposed to UV radiation and to extremely shallow penetration depths (frequently less the 0.01”).
    - UV degradation does not continue when exposure to UV is terminated.
    - UV radiation will not penetrate even thin shields such as paint coatings, clothing, or wrapping.
    Based on these studies, Harvel Plastic, Inc. recommends that PVC and CPVC piping products (i.e. pipe, duct, & shapes) exposed to the direct effects of UV radiation be painted with a light colored acrylic or latex paint that is chemically compatible with the PVC/CPVC products. Compatibility information should be confirmed with the paint manufacturer. The use of oil based paints is not recommended.
    When painting the effects of exposure to sunlight are significantly reduced, however, consideration should be given to the effects of expansion/contraction of the system caused by heat absorption in outdoor applications. The use of light colored, reflective paint coating will reduce this affect, however, the system must also be designed and installed in such a manner to reduce the effects of movement due to thermal expansion.
    It should be noted that Harvel’s standard formulation of PVC compound (H707) used in the manufacture of our rigid pipe contains 1-1/2% titanium dioxide (Ti02), a natural UV inhibitor. Harvel’s Corzan compounds used in the manufacture of rigid CPVC pipe contains at least 2% Titanium Dioxide (Ti02). Harvel’s Clear PVC piping products do not contain UV inhibitors and should not be exposed to UV radiation.
    I found some other stuff that indicated it's not much of an influence at all but I think those studies only went out a couple of years......not nearly as long as we are talking about. JohnT suggestion not to bury really old pipe is likely a good one.
