Thread: Is 1 gallon at a time to much MA to add at once ?
    Trying to get my TA down from 150 to around 60 or 70 and have added a gallon of acid the last 6 days and it will drop down but then go back up for some reason ,not sure why, im trying to get the ph down and aerate to get the ta down but it just seems to keep going back up. Anyways im turning the pump on recirc and adding a gallon at a time each morning but wondering if thats to much to add at once, my pools pretty decent sized 28-30,000 gallons with a pebbletec finish. Whats your take ? Thanks also would alot of natural rocks set in the pool change the chemical balance by chance ? thanks
    IG pool, 30,000 gallons, Aqua rite turbo SWG system,aqua logic ps8 unit,Midnight sea wet edge satin matrix , hayward 360 sand filter,hayward navigator,tristar waterfall pump,(hayward vs pump hopefully soon)autofill (well water), waterfall-grotto-tile slide. STARTUP oct 20,2007,
    Aug 2007
    Northeastern Ohio
    178
    Re: Is 1 gallon at a time to much MA to add at once ?
    The amount of acid to add is dependent upon how high your PH is AND how high your TA is. In order to get your TA down, you need to lower your PH to 7.0-7.2 and aerate to bring it back up. You can use JasonLion's Pool Calculator to determine exactly how much acid this is. Be very careful to not lower your PH below 7.0.
    If you haven't seen it, the Lowering Total Alkalinity pool school posting is very helpful.
    I'm no expert, but I can't imagine a reason for rocks to change the chem balance. Perhaps someone else can speak to that.
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
    Yes, what robrinker said. The crucial thing is the PH level, not the particular quantity of acid involved. You need to use the correct amount of acid to reach the desired PH. If you take the PH down too far you could damage the plaster and the stone work.
    May 2008
    Wisconsin
    4
    Quote Originally Posted by tillys26
    I too have natural stone (limestone waterfall in my case) & pebbletec. When I started, my alkalinity was in excess of 250. I'm wondering if it wasn't from the stonework as recent rains & my fill water isn't nearly as high. I followed the advice of the aforementioned links adding about 1/2 - 3/4 gallon of acid at a time to get pH about 7.2 & running the waterfall 10-12 hours per day. It took a few days but my alkalinity has since been steady at 80-100. I went through about 4 gallons of acid before it was done.
    Borate & a couple of bags of solar salt added since and now thanks to the advice of this forum & the BBB method , just a few cups of acid every few days and about 1/2 gallon of 12.5% chlorine per day & the water looks awesome with near-perfect chemical balance.
    17x40 PebbleTec IG ~23,000 gals
    (1hp Pentair) & (Pentair Tagelus 30" sand filter)
    (1hp Pentair) Vanishing edge [No Filter & The basin acts like a big skimmer-GROSS]
    (3hp Pentair) 12' limestone waterfall /w pond [so much for a SWC]
    (3hp Pentair) 22' SlideScapes slide
    Coverstar power cover Levolar auto-fill (currently on the fritz)
    Pentair MasterTemp 300 natural gas heater
    Frog XL Pro [not using, now on BBB]
    EasyTouch [PB bid out an IntelliTouch but that is another story]
    I brought my TA down to 130 from 280 over a course of several weeks using no more than six cups at a time.. usually three. I figured better safe than sorry.
    2003 Marquis Euphoria - 400gal
