Results 1 to 15 of 15
Thread: Check System No Flow on spa only
    Feb 2013
    Jupiter, Florida
    73
    Saltwater pool with Hayward system and chlorine generating cell. Pool is running fine, no issues. Turned the spa on tonight to heat it up and it ran fine for about 10 minutes and then would shut off. Display said "Check System-No flow - Filter". I could turn the filter back on and it would run fine again for another 10 minutes and then shut off. I haven't a clue what is going on. Any hints? I had a tech out for another problem last week and he reset all of my settings. Any comments appreciated!
    38,371
    Re: Check System No Flow on spa only
    Are you saying the SWG shuts off? Or the heater shuts off? Or the pump shuts off?
    The SWG would not be surprising because the flow switch is usually plumbed in the pool loop so the spa does not get over chlorinated while in use. But that should not turn off the heater or pump.
    Feb 2013
    Jupiter, Florida
    73
    Sorry for my bad explanation. Pool filter runs on the timer all day, no problem. Chlorine generator is at 60% and running fine. Filter shuts off as it should when time runs out. I turned the spa on manually last night to use with heater in auto control mode and set at 95 degrees. It filters and begins heating but after 10 minutes the entire system shuts down, filter and heater. That's when Check System -No flow - filter is displayed. I can manually restart it and it filters and heats. 10 minutes later same thing.
    38,371
    What automation system?
    Add your pool details to your signature please.
    Feb 2013
    Jupiter, Florida
    73
    Sorry for the lack of info. I have a 17,000 gallon saltwater pool with Goldline Aqua Logic PS-8 controls and Aqua Pod Remote. Also a Hayward Turbo Cell GLX-Cell-15-W chlorine generator.
    2006 IG 18.6K gal marcite saltwater w/integrated 800 gal spa, spillover, 2 Main and 2 Spa Drains, 2 Skimmers
    Goldline Aqua Logic PS-8, Aqua Pod Remote, Hayward GLX-Cell-15-W SWG, Hayward Pool Vac XL, Cartridge filter, single speed pump
    Taylor K-2006, Lamotte Borate Strips
    38,371
    Can you add a picture of your equipment/plumbing layout? I see that error listed in the manual, but can not figure out why it would be thrown. I am thinking that there is a setting that got lost in the reset ...
    I am guessing that your flow switch (which is only for the SWG) is in the pool loop and while in spa mode the flow switch is not closing and the system shuts down for safety. Likely there is a simple setting that just needs to say to ignore the flow switch and leave the SWG off in spa mode.
    38,371
    Assuming what I said above is true ... try this.
    Press the "Menu" button until you get to "Settings Menu"
    Then press the ">" button until you get to "Spa Chlorinator"
    Make sure that is set to ZERO using the + and - buttons
    If that is not 0 then the SWG will try to generate in spa mode, but if the flow switch is not in that plumbing loop, then it will shut down. Honestly I am surprised it shuts the pump down and not just the SWG. So maybe I do not fully understand the issue yet.
    What pump and filter do you have?
    38,371
    Just found another possibility which is more likely the issue.
    There is a function called "Flow Monitor" which will shut down the pump if it does not sense flow on the flow switch. Again, if the flow switch is in the pool loop, then it will not sense flow in spa mode. If this is how the plumbing is set up, then you will need to disable this feature.
    Press Menu button to get to "Configuration" which is locked
    Press and hold < and > for 5 seconds to unlock
    Press > or < to scroll to "Filter Config"
    Press + to enter pump options
    Press > or < to scroll to "Flow Monitor"
    Press + or - to toggle to "Disable"
    Feb 2013
    Jupiter, Florida
    73
    Thanks Jason! I have been gone all day but let me go check. Now that you mention it I remember, prior to the reset, the chlorinator was at 0 on spa mode. I believe it now reads 30%. I will review....
    Feb 2013
    Jupiter, Florida
    73
    Tried both solutions, second one worked! Flow monitor is disabled and spa stays on. Now for the big question.....does it affect anything else with it being disabled? Thanks for the answers/responses!
    38,371
    Glad it worked, I figured it would be the second thing. Should not hurt anything, most people do not have that kind of sensor. Honestly, I did not know it had this feature and wonder if mine is enabled.
    Feb 2013
    Jupiter, Florida
    73
    Well now I am back to my original problem which brought about the reset! My filter turns on and off at will. Prior to the flow monitor issue above it was coming on at odd hours. It even came on when I had the filter out for cleaning one day. Called a local tech out who ran through the settings, reset it, and it started working normally. No miscellaneous on and offs, just when the timer was set. Then we used the spa and noticed the problem that started this thread. I reset the flow setting as discussed above and no I get up this morning an pool has turned itself on again. Any clue as to why this would be so?
    38,371
    What is the air temp? Only thing I can think of to do that would be freeze protection.
    Feb 2013
    Jupiter, Florida
    73
    I'm in South Florida so the freezing isn't an issue. I have the temp settings set well below the actual temperature. Then again, since I had the technician out, the one who did the reset, I haven't checked to be sure. Will look at it this afternoon.
    Feb 2013
    Jupiter, Florida
    73
    No issue with freeze settings, set at 55 degrees. That's well below our low temp.
