Results 1 to 11 of 11
Thread: 1st Timer - test results
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    Hey folks,
    Ive been a long time user of the poolfrog and have seen the light and converted over to the TFPM. I ordered the TF-100 and got the following on my 1st test
    FC - 8
    CC - 0.5
    CH - 125
    TA - 30
    CYA- 70
    PH - 6.8 (maybe less)
    24ft round above ground Vinyl liner , sand filter... That gets a TON of direct sunlight
    I used the pool Calculator and added in half (about 50 oz by volume) of the recommended dosage of Baking Soda this evening and plan on retesting the TA and PH tomorrow.
    I uncovered and filled the pool today. There was some debris settled at the bottom that I vacuumed out. Still some of it stirred up and more settled at the bottom as you can see in the pic
    Am I on the right track?
    Once my numbers are within range, How often do I need to test? Daily ? Every other Day?
    Any help or suggestions is greatly appreciated!
    24 ft Round Above Ground - 13500 gallons... Former Pool Frog user. Sand filter . Located just South of Atlanta
    Re: 1st Timer - test results
    Welcome to TFP!
    You are doing fairly well.
    The only high priority item is to get the PH up. Raise the PH with borax until it is at least 7.2. Don't make further adjustments to TA until PH is handled.
    Normally you test chlorine and PH daily, everything else except CYA once a week, and CYA two or three times per season.
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    Thanks Jason, I will get the borax and add it in tomorrow. After adding in the correct amount via the calculator, how long should I wait to test again? The next day?
    Smykowski's Avatar
    Sep 2011
    3,065
    30 minutes with the pump running is plenty.
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    I just wanted to say thanks and everything is going well. Too cold to swim but as soon as it warms up some there's some crystal clear water ready to be enjoyed!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    As a former PoolFrog Owner, I can relate. Welcome!
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    I never had a hard time with the frog. I adjusted the water when I opened the pool and it ran pretty smooth afterwards as long as I didn't let the bac pac run out. The price of those things went way out of what I was willing to pay to maintain the pool. I'll take $3 bleach jugs and doing my own test happily.
    11,969
    I didn't start having "problems" with the Frog till year 4 or 5. But then, I was spending a min of $400 a year via Frog/pool store method. Now I spend roughly $75.
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    Hard to beat those savings.
    Casey's Avatar
    SW PA
    10,423
    Any crystal clear pics?
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    This is the most recent I have.
