Results 1 to 8 of 8
Thread: hayward aquarite salt generator issues
    May 2014
    orlando fl
    7
    my aquarite salt generator is showing 4000 for salt and the display works fine. no lights are on it is not generating. i just installed a new cell last week. It started working just fine salt level started going up from 1400 to now 4000 and lights stopped working no lights are on.
    the controllers displays this when i scroll thru
    4000
    87 degrees
    9.0
    0.00
    97p
    -0
    al-1
    r1.40
    i have it set at 50%. salt test was done today 2550ppm
    pls help
    Re: hayward aquarite salt generator issues
    How old is the control unit and what model of replacement cell did you install?
    The 9 is 9 volts. When not generating, that should be about 32 volts. I would suspect a failed current limiter.
    Jason's questions about the age and new cell will help determine if the limiter is the likely cause.
    Support the site
    May 2014
    orlando fl
    7
    The unit is 8 yrs old. The new cell is a compucell t 15 this is the same brand and type I have had for last 4-1/2 yrs
    At 8 years, and with the symptoms, I would recommend checking the current limiter.
    Support the site
    May 2014
    orlando fl
    7
    Great how do I check/change out?
    May 2014
    orlando fl
    7
    which part and where do i get it
    38,475
    Plenty of info to be found in here that may help figure out the problem:
    http://www.troublefreepool.com/threa...-lights-not-on
