Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: TF-100 Test Results-please advise
    May 2014
    by that Big Arch
    25
    24 foot by 4 Round Vinyl at 90% capacity (12150 gallons)
    71 degree temp water
    8psi filter pressure
    ph=7.2
    cl=5
    br=10
    tc=5
    cc=0
    fc=5
    ch=375
    ta=120
    cya=30
    running pool math calculator it shows to add 20 mule team borax..have not added anything until I hear from you guys..please advise
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: TF-100 Test Results-please advise
    To raise pH. all you need to do is aerate. Not that you really need to raise pH; 7.2 is acceptable.
    Since it is early in the season, I would raise CYA up to 50. It will tend to drift down slowly through the season. By raising it now, you will have taken care of it for the whole season.
    30,419
    How does your water look?
    May 2014
    by that Big Arch
    25
    crystal clear all the way to the bottom which for the first time in years (thanks to this site) you can see your feet and the bottom of the pool..now I/we were gone for 2 days with pool pump off and when we got home we cleaned it up as best we could (brushing, etc)..still have some leaves to removes (50mph wind and hail did not help last night) but we are getting real close but at least we could finally see the dirt on the bottom (thanks a ton guys)...i did add 1 more gallon of 12.3% shock even though high temps here starting tomorrow are going from highs near 90 degrees to the 60's
    ps: panty hose "sock" filter in the skimmer is one fine idea..I robbed all her tights I could find (she was not happy) but that cheapo filter trapped a lot of the nasty pollen/leaf debris we had floating on top (pump filter basket stayed clean..yippee)..the "sock" does seem to work well
    30,419
    Very nice. You are on top of your chemistry. Stay that way and have a TroubleFree swim season.!
    Jun 2007
    Houston, Texas
    209
    Everything is looking good BUT your CH is bordering the high side so make sure no one puts any more Cal Hypo in the pool. I assume you added liquid chlorine when you said a gallon of shock but always best to confirm.
    Also, when you get a chance, it's always a good idea to add your pool info in your signature so folks can better help. Sounds like you're in for an awesome swim season.
    36,000 gallon IG Gunite (40 x 20), 1.5 HP Hayward pump, Pentair Nautilus NS-48 DE filter, 2 skimmers, 12 - (2 x 20) Fafco Solar Panels (Goldline controller not hooked up yet), Hayward Swimpure Plus SWG, Blue Pearl Robot cleaner. New Dr. Wellness X-12 standalone Lifestyle Spa.
    May 2014
    by that Big Arch
    25
    liquid chlorine only (menards on sale stuff)..no powder junk
    Butterfly's Avatar
    South Carolina
    10,045
    Ignore the Br on the OTO tester. That is for bromine and you have a chlorine pool
    You're in for a great summer with your pool!
    You're done SLAMing when:
    May 2014
    by that Big Arch
    25
    I will add 1 pound (measured on scale-placed in sock to slowly dissolve) of cya (buying the cheap stuff at kmart) later this week..i will run the gamut of tests next week or so as we are expecting highs in the 60's tomorrow (where did summer go?)...right now pool is crystal clear to the floor and all that is left is vacuuming the remaining..sock filter in skimmer is working great (whoever mentioned panty hose i say thank you)...personally i detest pools and swimming but I have to admit this have been fun and well the kid and her will have an enjoyable swim year...Tf100 worth the cost, sock filter while gimmicky works, speed stir worth every dime, aerator to follow soon..
    May 2014
    by that Big Arch
    25
    latest results
    water temp-64.1
    FC-6.5
    CH-325
    TA-120
    PH-7.5
    CYA-will wait a week then retest
    heavy rain here (3 inches) with chemistry affect minimal to zilch at best
    crystal clear to bottom-I may add 12 ounces of 12.5% liquid chlorine as right now with pollen/leaves I want to hang with FC near 7..results look terrific to me
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Everything looks good from here. Your CYA addition, did you shoot for 50 ? If you did target your FC 7-8 and don't let it fall below 4.
    Your correct about the rain having no effects on your chemistry. You would have to have A LOT of rain or runoff into your water to have an effect on your chemistry.
    If your having a lot of pollen try using the knee high over the skimmer basket. On high pollen days check it often as it will catch a lot of junk and can restrict flow to your pump. 😎
    Jeff
    Casey's Avatar
    SW PA
    10,438
    Looks good! You seem to be getting the hang of it!
    May 2014
    by that Big Arch
    25
    CYA right now is near 30 (I know very subjective test with the black dot)..id like to be around 35ish as summer we do get a lot of sunny days..right now it is cloudy and miserable for next week..I plan on adding 1 measured pound and do the test after a week..then adjust accordingly to get near 35ish (if CYA hits 40 I can be Ok with that)
    ps: turned pump filter off and limited backwash from here on out llike its suppose to be (its happy at 10psi)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes 40 would be a good place to be with your CYA. you'll get more protection from the sun then. Just adjust your FC level accordingly.
    I just thought you were going to 50 by the prior advice from Jason. Whatever the level you end up with make sure you give yourself some wiggle room with targeting FC so you don't fall below your min FC. 😎
    Jeff
    May 2014
    by that Big Arch
    25
    added 1 pound of CYA today (sock in skimmer method I measured about 30ish)....i am losing about 2ppm of chlorine per day..will add 42oz of chlorine tonight (2.5FC with 0.CC)..water is crystal clear to bottom but am fighting tree seeds, wind, T-storms (typical stuff)..pool store has made comments about what we are doing this year..I am no longer pool store screwed...thanks for all the advice/help-god speed
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Don't forget that CYA you added today will take up to week to fully register on test. 😎
    Jeff
    May 2014
    by that Big Arch
    25
    thanks..i will not re-test until next week..
    May 2014
    by that Big Arch
    25
    CYA is finally above 40 (42ish)
    cc=0
    fc=1
    water temp at 59.9 degrees..yeah global warming my butt
    will add 61oz of 12.5% tonight..we have been hit here with a week of T-storms and I have not added any chlorine..water crystal clear to bottom after a thourogh cleaning (leaves from storms/etc)
  20. Back To Top    #20
    May 2014
    by that Big Arch
    25
    pool closed down..its way to cold to even swim..pump shut off...going to run pump some to circulate chlorine which I have not even added in last 5 days..pool never looked better,,still crystal clear throughout..
