Results 1 to 10 of 10
Thread: Discolored steps
    Sep 2008
    Philadelphia
    43
    Discolored steps
    Just opened our 7-year old vinyl liner pool.
    The (I assume acrylic) plastic steps have some discoloration/staining on them.
    The stain does not brush away nor does my pressure washer do anything.
    There did not appear to be anything like leaves etc on the steps when I took off the cover 2 weeks ago.
    Any suggestions for getting them white (or less brown) again?
    pH and chlorine levels are now in normal range.
    Bob
    25,000 gallon
    16' x32' Rectangle IG, Vinyl liner
    DE filter
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Discolored steps
    Check Pool School for stain removal. You will probably have to try several different methods to at least lighten those.
    Smykowski's Avatar
    Sep 2011
    3,065
    If you have a puck, put it on top of one of the stains for a few minutes. If it disappears, it's organic. Otherwise, buy some vitamin C tablets, crush them up, and wrap them in an old sock/nylon and lay it on the stain. If it disappears then, it's metals.
    Can you also post a full set of test results?
    Sep 2008
    Philadelphia
    43
    Thanks guys! Fast service!
    A bit occupied due to mother's day duties but will try recommendations and get back with results.
    25,000 gallon
    DE filter
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    I use those white Mr. Clean or generic scrubby things -usually two per box. Works like a charm!
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    Sep 2008
    Philadelphia
    43
    Testing with vit C tablets prove it is iron or similar staining; steps were white again around the tabs. Chlorine hockey puck did nothing.
    I've ordered 5 pounds of ascorbic acid powder and will follow info at: http://www.troublefreepool.com/threa...f-metal-stains
    So which sequesterant to use after the vit c?
    Blue Stuff from magic Jacks'? Stuff seems awfully expensive.
    Any thoughts on:
    Periodic Products CUL-1MO Culator/Metal Eliminator and Stain Preventer for Swimming Pools
    http://www.amazon.com/gp/product/B00...pf_rd_i=507846
    Current ph is 7.1-7.2.
    Chlorine is 0.5
    Thanks!
    25,000 gallon
    DE filter
    Casey's Avatar
    SW PA
    10,453
    I can't advise you on which sequesterant to use but I believe Jacks gets the thumbs up around here. I do know that it's recommended to be used weekly. Do you fill on a well? Just wondering where the iron came from?
    Sep 2008
    Philadelphia
    43
    No; city water and I don't think it has high iron.
    I do get ground water behind my liner and I think that it gets into the pool over winter. That water is likely high in iron due to galvanized panels behind liner. Only thing I can think of.
    Another of the many joys of pool ownership! The gift that keeps on giving.
    25,000 gallon
    DE filter
    Sep 2008
    Philadelphia
    43
    Ok, update.
    The ascorbic acid did wonders! About 1 day later the water was crystal clear; pool looked brand new.
    I ran the DE filter for 3 days; pulled out filter finger part of filter, washed it out, and recharged with fresh DE.
    I then put in some stuff my local pool place recommended.
    All was good til Wednesday of this week: I'm back to greenish/brown water as of 3 days ago; seemed to happen after adding my bleach (read 0 Cl on test kit).
    Pool place tested water this morning:
    Free chlorine: 4.07 ppm
    Total chlorine: 4.67 ppm
    Combined chlorine: 0.6 ppm
    pH: 6.4
    Hardness: 20 ppm
    Alkalinity (w/stabilizer correction): 22 ppm
    Cyanuric acid: 17 ppm
    Copper: 0.3 ppm (recommended range: 0-0.2 ppm)
    Iron: 0.1 ppm (recommended range: 0-0.3 ppm)
    I added in 1 qt of their "Stain and Scale Control" which is a "special product of polymer chemistry". All was fine.
    I kept checking chlorine level and would add in about 1/2 bottle of bleach every other day but couldn't get Cl level to go up.
    Added 1 bottle after a day off. Still nothing. Added 1/2 bottle and now brown water and Cl level high.
    I added in another bottle today of the "Stain and Scale Control" and haven't seen any change after about 8 hours.
    I'm guessing I'm seeing copper in the water (I've used copper-based algaecide in past) as it looks brownish not green.
    Their stuff is supposed to "cope with extreme problems due to minerals (calcium, manganese, iron, and copper).
    Any suggestions?
    Purple stuff? Blue stuff? Magenta stuff?
    Fill it in?
    Be patient and let stuff work?
    Thanks!
    25,000 gallon
    DE filter
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Just got thru treating my pool with AA....stains haven't returned but after treating it afterwards with Sparkle Conquest sequesturant 5 days ago have cloudy water. Clearing more each day. Have You read these directions? http://www.troublefreepool.com/threa...f-metal-stains
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
