Crack in line at spa drain to filter
war623
May 11, 2014
2
Plant City, Fl
I have a cracked line from the spa drain to the filter somewhere in this area. This is an inground pool with a spa. I know it is in this line because when the line is open, it is sucking sand into the filter. When I close the line off, it quits. I see there is a Spa Fix-A-Leak available at Amazon and wondering how well this would work.
I can see how it would work on a return line but cannot see how it can repair a supply line. Any input is appreciated on this and any other ideas you may have.
