Thread: Cal hypo has a very high PH
    May 2014
    Davenport, Florida
    1
    Quote Originally Posted by Casey View Post
    High calcium can lead to clouding of the water and if the pH gets too high, along with the calcium from over use, it can put an unsightly scale on your liner and ruin it. Bleach, which has salt (sodium hypochlorate) adds a minimal amount of salt to the water unlike Cal Hypo, Tri Chlor and Di Chlor and is the safest of all because it doesn't have additives that will drive the water parameters out of whack.
    That's not exactly true, in that sod hypo has a very high pH, circa 11-13, so if you don't add acid at the time you add sod hypo you will drive the pH up, because the sod hypo has a high acid demand. This increased pH then slows down the effect of the added chlorine, because of the inverse pH/chlorine relationship. Rule of thumb is for every jug (20 pints) of sod hypo added, also add a pint of acid. Obviously this only applies if the pH is correct before the addition of the sod hypo. If the pH is out then the amount of acid needs to be adjusted accordingly.
    Re: Cal hypo has a very high PH
    Welcome to TFP!
    Sodium hypochlorite and Cal hypo both have a fairly high PH, however the process of chlorine getting used up (either sanitizing or from breakdown by sunlight) is acidic. The net effect of adding either one is PH neutral when both effects are taken into account.
    30,403
    +1 what JasonLion said.
    I am curious as to the use of "sod hypo" what does that mean?
    Smykowski's Avatar
    Sep 2011
    3,065
    Sodium Hypochlorite?
