Thread: SWG newby questions
    lee872's Avatar
    Central Massachusetts
    59
    SWG newby questions
    I turned my SWG on yesterday for the first time this year. I had it installed at the end of last summer, so I'm not sure what to expect. Lights look good, only one is lit, "generating". A couple of questions:
    • When I first ran through the diagnostic displays, it all looked good. At that time the average salt was 3300 and the instant read was -3300. When I ran through the diagnostics a few hours later, the cell circuit was 0 and the instant read was -0. I unplugged the cell from the board, and plugged it back in. I immediately got a circuit read and an instant read. A few hours later, same thing, and again today -- it started this morning with circuit and instant reads, then went to 0 a few hours later. I unplugged and replugged and got readings. It's back to 0, and I am running it that way until I see what you all have to say. Am I really having trouble getting the plug in tight, or is something wrong?
    • Average salt level started at 3300, is now at 3700. My strip AquaTest strip test shows 2840. My optimum level per manual is 3200, so I aim for 3400 - 3600. Does the high read matter?
    FC 7.5 (compensating for adding water due to leak, and I over shot)
    CC 0
    PH 7.5
    TA 70
    CH 190
    CYA 50
    Water temp is about 64 -- SWG read is 66
    35,000 gallons - inground vinyl liner -- sand filter - 1 HP, 50.76 GPM - Aqua Rite T-Cell 15 SWG - Dolphin Apollo Plus - TF-100
    38,514
    Re: SWG newby questions
    It reads zero when not generating. The % setting is the amount of time it is generating. It cycles on and off.
    As long as the SWG is happy with the salt reading, then no problem.
    lee872's Avatar
    59
    I mispoke in my question, sorry. It's not the cell circuit that is reading 0; it's the cell current, or amps, that is 0. Does that also show 0 when it is not generating?
    Yes. Cell current is zero when the SWG is not generating.
    lee872's Avatar
    59
    Thanks, I was hoping that was the answer!
    Jul 2013
    Waxahachie, Tx.
    448
    Also, from Hayward I found out that the Aquarite % setting is based on a 2 hour cycle. So if you have the output set at 50% and run it for 2 hours it will generate for 1 hour.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
