Thread: how much CYA in one of these?
    Apr 2014
    lousiana
    105
    Exclamation how much CYA in one of these?
    ok so i really need to raise my CYA, mines probably around 20 or so and was wondering how much CYA is in one of these http://www.walmart.com/ip/HTH-3-in-1...blets/17043622 because walmart sells them in single packages....keep in mind mony is tight due to a trip to tennessee we are doing very soon, im asking cause the amount of bleach im adding a day is a lot and was hoping that raising the CYA will help keek some of the bleach in there for the next day......thanks guys
    2 year old 14x48 intex ultra frame
    intex 633 pump
    Re: how much CYA in one of these?
    You can use PoolMath to figure that out. Look at the effects of adding chemicals section towards the bottom. Typical trichlor tablets are 7 oz. It takes quite a while to raise CYA with trichlor.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Those pucks are 7 oz each. Your pool is 6981 gallons, according to intex. Looking at Effects of Adding Chemicals in Poolmath, each puck will raise FC by 6.9, raise CYA by 4.2, and lower pH by .37.
    Apr 2014
    lousiana
    105
    so not sure just one will do the job then
    intex 633 pump
