Results 1 to 7 of 7
Thread: Low Salt
    Jul 2011
    Webster,Wi
    62
    Low Salt
    Just starting to get the pool opened and cleaned, it has a very nice lime green tint right now. Last fall I drained half the water to just below the return and it frozen solid over winter which by the way was one for the ages. Anyway I have filled it up most of the way with no leaks and hooked up the pump and started circulating the water and added some bleach, my question is I know it is low on salt and the alarm did come on on the pump but will it hurt the cell to run with low salt? I will be getting to a store that sells pool salt on Wednesday.
    18'x52" Intex round AGP, 2650 Krystal Clear SWG pump with sand filter and a Hayward H100ID pool heater. TF100 test kit to keep the water sparkly clean.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Low Salt
    I don't know enough about SWG cells to know about running them while low on salt. However, you don't have to buy pool salt. You can buy solar salt from any big box store and it works the same.
    Re: Low Salt
    The SWG won't produce as much chlorine when it is getting a low salt error, but assuming it doesn't completely shut down it will product some chlorine and will not damage it's self.
    Jul 2011
    Webster,Wi
    62
    Re: Low Salt
    We live an hour away from any big box store but the local gas station-convenince store sells the pelletized salt for sidewalks in the blue or yellow bags, is that something I could use?
    Mar 2007
    Murrieta, CA
    215
    Re: Low Salt
    Quote Originally Posted by MK1985 View Post
    I wouldn't trust the road salt without knowing what's in it. May not matter for an AGP, but you never know. Is there no way to turn off the salt cell?
    Probably safer to just add bleach for a few days until you can get some high-purity salt. That's what I would do.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Low Salt
    Even with the right amount of salt, a SWG won't be able to generate enough Fc to kill off an algae bloom.
    Jul 2011
    Webster,Wi
    62
    Re: Low Salt
    I will check in the instructions to see if I can turn off the cell and then just add bleach until I get the salt. I was just concerned running it with low salt alarm that it could hurt the cell but it doesn't look like it would.
    The bleach I added yesterday seemed to have helped, the green color is gone today and without doing a test I know I still might have problems but I was concerned about running with the low salt alarm.
