Thread: Low water level after winter close. . .
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Hey;
    We're about to remove the pool cover after a tough winter on our above ground pool. Haven't found the cause yet, but it's obvious that the water level dropped way down over the winter. I have 2 questions pertinent to this:
    How low can water go down before the liner is considered damaged?
    Is there a way I can tell that it's no good before I fill the pool up once again?
    Thank you.
    Ed
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Low water level after winter close. . .
    If thee is at least a foot of water remaining in the pool, you should be OK. Carefully check along the current waterline for any holes, rips, tears, etc. Now would be a good time to patch them if possible, if the hole(s) aren't to big. This may mean getting into a rather cold pool to do the inspection.
    Good luck!
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    SORRY - MISSED THE ABOVE GROUND PART ... my answer doesn't apply (i think anyway) and i couldn't delete this post.
    Quote Originally Posted by Whatrymes View Post
    Hey;
    Thank you.
    Ed
    I had the same issue (upstate ny) and i have seen another post or two about it. My pool lost a foot at least and the liner was floating off the walls and a little portion of the shallow end. I was able to refill the pool and try and get the liner back in place with the pool brush and my liner is back in place with just a couple of wrinkles in the shallow end. After filling it back up i don't appear to be losing any more water.
    One of the guys on here is a full time pool guy an hour or so away from me and he mentioned it could have been from the hydrostatic relief valve opening and then not closing properly right away and eventually working its' way shut. He has seen that before and some pools actually lose all of their water!
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Thanks guys;
    So, the cover is off and there's 'bout 20 - 24" of crystal clear water on the bottom. I feel the liner is fine but I'm going to need to investigate this problem. I have difficulty with the water level and trying to remove water from the top of the cover without draining the pool, seems like every year.
    10,800 gallons
    TF-100 Test Kit
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Could it be that there is some seepage through your cover? Mine does that a little, but mine is a modifies poly tarp. Not a good quality cover.
