Results 1 to 11 of 11
Thread: First test results
    Mar 2014
    Olalla, WA
    9
    Question First test results
    Hi,
    I just received my TFT test kit. I am new to having a pool and look forward to all I can learn from you folks and hope to contribute someday. Ok, first results:
    FC=1
    CC=0
    TC=1
    PH=7.4
    TA=120
    CH=150
    CYA=98
    TEMP=58 degrees
    I just recently got rid of a small algae bloom. How does this look?
    Thanks in advance!
    Bonnie
    Vinyl In-Ground Pool
    Gallons - 15,000 ?? - Not sure
    Olalla, WA
    Casey's Avatar
    SW PA
    10,423
    Re: First test results
    Welcome Bonnie. Looks like you are in for a partial drain/refill with that high CYA. It's truly your first step. You will use way to much chlorine just to get the minimum FC level, let alone SLAM'img levels! Have you been using pucks?
    Mar 2014
    Olalla, WA
    9
    Quote Originally Posted by Casey View Post
    Yes, I have been using pucks. How much would I need to drain? (dang...)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    First test results
    If you use Pool Math it will tell you how much water to replace to lower CYA X amount. Just plug your numbers in the now and what your target CYA level you want to reach. Don't forget to add your pool water volume at the top.
    Also if you could add all your pool and equipment info to your sig that will help us better help you. 😎
    Jeff
    Casey's Avatar
    SW PA
    10,423
    The pucks caught up with you just like they always do. At least now you know. If you have any left, save the for vacation.
    Mar 2014
    Olalla, WA
    9
    Thank you!!! I am going to retest CYA one more time (I did more reading on the test process) and will start dumping and refilling per the pool math calculation.
    Bonnie
    Outdoor Vinyl IG 16'x32' 15,000 Gallon
    Hayward Super Pump
    Hayward S-244T Sand Filter 62 GPM
    Mar 2014
    Olalla, WA
    9
    New test results for 5/12 5:29 pm
    FC=.55
    CC=0
    TC=.55
    TA=100
    CYA=70 (didn't replace enough water)
    CH=150
    PH=7.5
    So, using the pool math calculator:
    I should add bleach and borax/soda ash/washing soda
    Is that correct? If so, do I do one before the other? Or do I need to do something completely different?
    Thanks!
    Bonnie
    Hayward Super Pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    .55? What test are you using?
    Your PH and TA are fine so you don't need anything except chlorine...
    How does your water look? That would determine if you need to lower the CYA more or if you can get by with that level for the rest of the season. Backwashing with your sand filter the level will slowly drop over the summer.
    Mar 2014
    Olalla, WA
    9
    Quote Originally Posted by frustratedpoolmom View Post
    I will have to retest FC...sorry. The water looks crystal clear.
    FC=7.5 - duh on my part!
    Bonnie
    Hayward Super Pump
    11,969
    Well I would suggest then that you do an OCLT and determine if your FC is holding overnight. If it is, you don't need to SLAM and you can try and run with the CYA at 70. You just need to be diligent and keep the FC above the "Min" at all times - no cheating. LOL
    My first summer on TFP 7 years ago I lowered my CYA from 140 to 70 and ran it there the rest of the summer. Was fine.
    Mar 2014
    Olalla, WA
    9
    I will do the OCLT test tonight and tomorrow am - thanks much.
    Bonnie
    Hayward Super Pump
