Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: This One's New to Me
    Dec 2009
    Virginia Beach, VA
    131
    So I'm opening my pool this year and when I pull the cover off the water's much clearer than I've ever seen it at opening but there is a black layer of I guess algae?? on almost the entire bottom of the liner. It brushes off easily but like I said I've never seen it before so I'm confused a little. I'm currently filling the pool but need to know what my process should be for chemicals and brushing/vacuuming. I'm guessing I should go do this:
    1 - Add CYA
    2 - Start the SLAM process and brush down the walls
    3 - Finish the SLAM process
    4 - Vacuum to waste
    5 - Get TA, PH, and CYA correct
    6 - Probably vacuum again (through filter this time)
    Does this seem correct? Here are some pictures...
    30,000 Gallon Inground, Vinyl Liner
    DE Filter & Pentair IC40 SWG
    Pentair Legend Platinum w/ PB4 Booster
    Pentair Kreepy Krawler Prowler Robot
    Casey's Avatar
    SW PA
    10,461
    Re: This One's New to Me
    That looks like leaves to me but regardless, you're going to have to rake the bottom out before you start SLAM'ing the pool. Once you get them out and are running the filter, check pH, CYA, make adjustments and SLAM it.
    Smykowski's Avatar
    Sep 2011
    3,065
    Only two suggestions I have are to get your pH balanced first, and if you're going to vacuum to waste, do it before the SLAM so you're not dumping newly added CYA and bleach.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Use your leaf rake to remove as much bottom gunk as possible before slamming. Otherwise the chlorine will be attacking what you could have cleaned out and result in much more time needed to finish the slam.
    Test
    Get Ph to 7.2
    vacuum to waste
    If CYA is below 30, add just enoguh to get it 30 until slam is finished. (lower CYA saves chlorine)
    If CYA is higher than 30 but not above recommended levels, then leave as is.
    Slam Slam, brush brush and filter filter
    clean filter when reqired
    slam slam till you pass all 3 slam criteria
    adjust to recommended levels and then
    Divin Dave,
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yep it looks like some clean up if that is debris and a SLAM. If you could post up some test results for us to take a look at, we can point ya in the right direction if you need it. What test kit do you have ?
    Take a look a the SLAM process in Pool School and follow it the T ! Keep us posted on how things are going 😎
    Jeff
    Dec 2009
    Virginia Beach, VA
    131
    Thanks for the tips everybody, that's why I love this site.
    It's not leaves, my cover was on there pretty tight and I used the leaf rake to get some of it off. But when I pulled it up it was pretty fine stuff, I'm guessing its algae that's just covering the bottom of the liner. Its just crazy cause it looks like a solid sheet. I'll take the approach Divin Dave laid out with the exception of moving vacuum to waste to the beginning and then refilling prior to testing and getting the pH right. Not much use of getting that right then vacuuming to waste right?
    Anybody got any tips on vacuuming to waste without dumping so much water out of your pool? I must vacuum really slowly cause it takes me like 30 min to do my pool and that's a LOT of water to dump.
    Casey's Avatar
    SW PA
    10,461
    Believe it or not, I've never vac'ed to waste so I don't know unless you move faster!
    Dec 2009
    Virginia Beach, VA
    131
    Yeah i typically vacuum to the filter just because I move so slow errr methodically.
    But with this much **** on the bottom I'd be going through some DE in a hurry...
    30,432
    You are correct. With a DE filter and cleaning up a swamp like yours, it is a trade off between constantly cleaning the DE or having to lose a lot of water.
    Frankly, I can't tell you which is best but it has to be one or the other.
    Running your pump for an hour or so might move the gunk around so it is in a central loctation and save you some vacuum strokes.
    Keep us posted.
    Dec 2009
    Virginia Beach, VA
    131
    Went to the pool store to buy a vacuum head cause my brushes were so worn that it was getting stuck to the bottom and he told me to just add the chlorine at the skimmer basket to get it to mix faster. Reading here it says to mix in front of a return. Is there any detriment to adding it to the skimmer as I'm sure it will mix faster that way???
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    That much of a concentration of bleach could damage the seals in your pump. That is why we recommend against skimmer additions of most chemicals.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yep pour that chlorine in front of your return with the pump running.
    Jeff
    Dec 2009
    Virginia Beach, VA
    131
    Quote Originally Posted by Charlie_R View Post
    I thought I had read this somewhere. Thanks for the advice.
    Dec 2009
    Virginia Beach, VA
    131
    Just wondering why I'm supposed to get my pH to a level of 7.2 when the chart says 7.5 - 7.8. My current level is 8.0 so I don't want to bring it all the way down unnecessarily if I don't need to. Please advise.
    Smykowski's Avatar
    Sep 2011
    3,065
    In most pools, the pH will gradually climb. During the SLAM, you won't be testing or adjusting pH. By starting at the low end of the range, you allow plenty of room for it to move while you concentrate only on FC.
    Also, 7.2-7.8 is a safe range.
    Dec 2009
    Virginia Beach, VA
    131
    All right, we have entered the SLAM phase of the opening. How long does it take after adding the bleach before you can accurately test the FC?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Let it circulate about a half hour, then add more if needed. Use PoolMath for your dose amount, and see how close that gets you.
    Then every hour or two after that, test and dose.
    Dec 2009
    Virginia Beach, VA
    131
    Gotcha. Two more questions.
    1 - I have a Polaris. Would it help to turn it on during the SLAM process? I figure it could help keep the algae stirred up so the Cl can kill it.
    2 - At what point do you go from Recirculate to Filter? After the SLAM process is complete?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    You can use the Polaris while SLAMming.
    When the goo in the pool turns mostly grey, then go to filter. Be prepared for several DE changes your first day.
  20. Back To Top    #20
    Dec 2009
    Virginia Beach, VA
    131
    I've got another question. When I did my FC tests yesterday and this morning, the results were a little unclear. When I added the reagent drops, the water would turn clear initially but if you waited a second or two it would turn back to a light pink. This isn't what I'm used to. I'm used to it staying clear and if it does go a hint pink, one more drop would turn it permanently clear. This morning it initially turned clear at 12 ppm but didn't stay clear until 21 ppm (and even then it turned back to pink eventually). Which reading do I go with, when it initially turns clear or when it stays clear?
    When I initially added my powder it turned a light pink and I thought my FC was really low. Then I added a couple of drops of reagent and it turned the dark pink I'm used to when there is a lot of FC. Is my powder just dissolving really slowly? I opened up some new reagents (powder and liquid) yesterday but I probably ordered them 8 months ago and have just been holding them until now. Do I have old reagents? What's the shelf life on these? How often do I need to order a whole new TF-100 refill kit? I ordered new CYA early last year and new Cl and calcium hardness late last year but the other stuff is likely 2 years old at least.
    Thanks guys.
    Oh and the pool's looking much better already. The water's quite cloudy but the black on the bottom is gone and it's the usual color of light green I'm used to at startup. Hopefully it'll be swimmable by Wednesday.
