Results 1 to 9 of 9
Thread: Advice on cleaning hair from canine hydrotherapy pool
    May 2014
    Taunton
    8
    Hi - hope I can get some ideas for reducing the cleaning in our hydrotherapy pool.
    We have an 6m x 3m above ground pool which we use for canine hydrotherapy. As you would guess we get a lot of hair in the pool every day.
    The skimmer net does a good job but there is always a lot of hair floating round on the surface and settling on the bottom of the pool overnight.
    I am trying to find a system that will reduce the amount of cleaning each morning!
    At one end of the pool is a stainless steel resting platform on legs which is a bit like a 50cm high table. Would this tangle up a automated pool cleaner?
    Cheers
    Mike
    Casey's Avatar
    SW PA
    10,422
    Re: Advice on cleaning hair from canine hydrotherapy pool
    Welcome to TFP!
    Do you have any pics of the pool? Can you tell us about your pump and filter and add it to your signature please? I would imagine that an auto vac could get tangled up in the legs of the platform. How are you vacuuming now?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The cheapest option I can think of is likely going to be a Kreepy Krauly style suction side cleaner. As to the tangle potential, that is anyones guess, and may depend on the individual cleaner, before I made the switch to robot cleaners I owned several different models of suction side cleaners over the years, some expensive ones would constantly get wedged in a corner by the ladder, and some cheap ones might never get caught (but did tend to fall apart in short order)
    May 2014
    Taunton
    8
    Hi - we have a magic 8 pump and sand/glass filter
    Photo of the pool
    http://www.h2ocaninetherapy.co.uk/ourfacilities.html
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP Mike!
    Essential Links:
    Butterfly's Avatar
    South Carolina
    10,045
    You might want to consider a PoolSkim. Do a site search for it + dog hair
    Are you using skimmer socks?
    Welcome to the forum
    You're done SLAMing when:
    May 2014
    Taunton
    8
    Thanks for the welcombe
    We do use skimmer nets - a new one most days!
    I love the idea of a creepy crawly type cleaner but i think it will wedged around the ramp and steps.
    Mike
    30,403
    On a 20' x 10' pool which I assume is not very deep, I think a robot might be more trouble than it's worth.
    My guess is that area can be manually vacuumed in 10 minutes or less which would hardly justify putting the robot in the water.
    May 2014
    Taunton
    8
    Because the hair is so light it only just settles on the bottom overnight. The pool vac then mixes it up and pushes it ahead it takes 30 min minimum to hoover to pool every day. That's just to get the settled hair off the bottom, we also have to daily net the surface for floating hair and clean the filters. It's not a problem as it part of the job I am just looking for ideas to save time and some way to automatically clean the bottom of the pool would be a big help.
