Results 1 to 8 of 8
Thread: Not sure if this is the right place.....
    TexCin's Avatar
    Jul 2008
    Spring, Texas
    7
    My IG gunite pool has gray marks in several place, the worst being in the spa. You can't feel anything if you touch them, but they are unsightly. I've attached a picture....any thoughts on what this is and how to get rid of would be appreciated.
    Cindy
    36x16 gunite, 14,500 gallons, Jandy 2.0hp VS Epump, Jandy CL460 filter, Automatic chlorinator, Jandy Legacy 400K BTU Heater, Polaris 1.5HP spa blower, 2 Colorlogic pools lights and 1 Colorlogic spa light, Polaris 3/4HP booster pump, Polaris 280 cleaner, Jandy PS4 with PDA, QuartzScapes Montego Bay plaster, OK flagstone coping, spray deck (aggregate effect) - completed 3/2011
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Not sure if this is the right place.....
    Wow. I'm not sure.....
    Someone will be along tho.
    I've seen it suggested to rub a crushed vitamin c tablet on the stain and if it fades, the stains are metal. Also with a chlorine puck, let it sit on the stain and if it fades, the stain is organic.
    Hopefully if there is another suggestion for you someone will chime in.....
    Welcome to TFP!
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I have something similar happening in my pool, figure an acid wash during the winter is due.
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    I have the same thing on my steps. After reading one of the posts about the vitamin C tab, I found some and rubbed on some places and just let the others dissolve. I was amazed at how the area that I just let it dissolve became brighter and no more streaks. So... I am going to do the ascorbic acid treatment I read on another thread (getting rid of pool stains). Hope that it gets better.
    Scott
    1) 24000 gal
    2) DE filter
    3) IG
    4) plaster
    5) 1 hp
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    czechscott
    Where did you find info on ascorbic acid treatment? Could you please refer me to that post?
    I wouldn't mind giving it a try.
    Thanks
    TxSkye's Avatar
    Apr 2008
    Danbury, Texas
    11
    5600 Gal.
    18'x48" Easy Set
    1500 GPH Pump/Cartridge Filter
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Thanks, I'll check it out.
    TexCin's Avatar
    Jul 2008
    Spring, Texas
    7
    Thanks to all for your suggestions...I'm on my way next door to borrow a vit c tab. I also posted this in the Algae part of the forum just to make sure its not algae, but this sounds like a consensus here...I'll try the vit c and then the AA.
    Thanks again!
