Thread: Pool leak detection?
    Aug 2013
    Hilton Head, SC
    133
    Question Pool leak detection?
    I know I'm losing water though some type of leak. I suspect either the tile grout or somewhere around the skimmer, based on where the water is settling in my neighbor's yard. I've tried the red dye injection technique, bucket test, and watching it overnight w/o running the pump.
    If it is in my skimmer line, is there a simple test before I call out the "camera squad"?
    TIA
    Ed
    4k, IG, Gunnite, Jandy Valve, 1HP Haywood, 2" flow, single 2" line for skimming & vacuum, Pentair FNSP 36 DE w/125 GPM Multiport 50 PSI, TF-100 Test Kit, built 1991, Hilton Head, SC
    Casey's Avatar
    SW PA
    10,442
    Re: Pool leak detection?
    Bumping to see if we can get you some help with this...
    Nov 2011
    Moberly,MO
    1,010
    Leak detection is time consuming attention to the finest detail procedure. Plug your skimmer line in the bottom and if the pool keeps leaking you know the line is ok. If you have a light check where the cord exits. Had a concrete crew drive stakes thru the light conduit and didn't tell anyone they hit it.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
