Results 1 to 8 of 8
Thread: TA is low
    Feb 2014
    Central California
    17
    TA is low
    Since taking over my own pool care 3 months ago things have been mostly good. I've been focused on keeping the FC and PH balanced with liquid chlorine and muriatic acid.
    I decide to check the TA and CH today. The TA came in low at 40... it had been around 100 when I last checked it.
    So I'm going to add baking soda to bring the TA up. How often do folks check some of the other chem levels.
    Thanks
    Today -
    TA=40
    CH=260
    pH=7.4
    FC=4
    CYA=30
    18K gal, IG Concrete (colored), Hayward C3025 cart. filter, Hayward Tristar 2-speed 1.85 HP pump, pool is 4yrs old, Hayward Navigator XL vac
    Re: TA is low
    I check TC & PH daily, everything else except CYA weekly, and CYA two or three times a year.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: TA is low
    What Jason said. No need to do any more than that.
    Casey's Avatar
    SW PA
    10,453
    Re: TA is low
    I check FC and pH regularly, TA monthly and CYA maybe 2x a summer unless I'm adjusting it.
    Feb 2014
    Central California
    17
    Re: TA is low
    Hi,
    I'm baaaack....
    So when I started this thread my TA was at 40. I got a 12lb bag of baking soda from Costco. Added the whole thing over a few days and brought the TA back up to around 100.
    But here we are a month later and when I checked my TA today it's at 60. I am adding muriatic acid every few days to bring the pH down. It will rise to 7.6ish and I bring it back down to 7.4ish.
    Just not sure if this is normal or not with the TA.
    Water is nice and clear (despite a recent visit from my 6 yr. old niece and nephew)
    Here are my latest test results -
    FC - 4.0
    CH - 300
    pH - 7.5
    CYA - 30
    TA - 60
    Jun 2013
    Fontana California
    56
    Re: TA is low
    Why not see if your pH will stabilize at 7.6 or 7.8 with a TA of 70 or 80? It could be that your TA is falling because of your constant additions of muriatic acid to keep your pH at 7.4.
    My TA was around 110 until I held my pH at 7.2 with muriatic acid for about a week. At the end of the week my TA was down to 70. Now that my TA is 70 I don't have to add muriatic acid as often because my pH doesn't rise so fast.
    14K Gallon IG Gunite Pool built in 2005, Century Centurion 1 1/2 HP Pump
    Pentair Clean & Clear 420 Sqft. Cartridge filter, MiniMax Pentair NT Heater, The Pool Cleaner
    Taylor K-2005 test kit with Taylor K-1515-A FAS-DPD Chlorine Test. SpeedStir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: TA is low
    Every time you add acid to lower pH, you also lower TA a little.
    What I don't understand is why you do you even bother adjusting it at 7.6 pH? Your CH is not so high that you have to watch CSI like a hawk. You may discover that if you leave pH alone, it will just settle in at 7.6 or 7.7 and stay there for weeks.
    Feb 2014
    Central California
    17
    Re: TA is low
    It's just me being new to this whole thing. I'll try getting the pH settled a little higher and see what happens.
    Thanks
