Results 1 to 13 of 13
Thread: ??? On Pump & Filter Size
    MermaidMama's Avatar
    Aug 2013
    Pennsylvania
    158
    Question ??? On Pump & Filter Size
    I'm getting an 18' round x 52 inch high above ground pool. I am getting a 1 HP pump and 1 HP filter. This is plenty for my pool size????
    MermaidMama
    18' Round x 52" Doughboy AGP ~ TF-100 Test Kit
    Powerline XP Pump 1.5 HP ~ AquaView 20" Sand Filter ~
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: ??? On Pump & Filter Size
    Quote Originally Posted by MermaidMama View Post
    1 HP filter
    Filters are not normally rated in HP. But without knowing the model # of either, it is hard to say. Are they the same as what is in your signature? Do you have a link to the equipment?
    Mark
    If at all possible get a two speed 1 HP pump, running on low speed will save you 50% of your pool related electrical bill.
    There is no such thing as a "1 HP" filter. Filters are generally measured in surface area, typically square feet, you also need to say which kind: sand, cartridge, or DE.
    Generally you want a larger filter than the sales people will want to sell you.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    An 18'x52" pool will do well with the 1hp pump.
    I've never heard of a filter rated in hp. Can I assume from your sig line that it is a 17" sand filter? If it is, then yes, that will work for your pool, although I probably would have gone with a 21" or bigger. You will have to backwash a little more frequently than with a larger filter.
    When it comes to filters, the bigger the better. More surface area to capture the fine particles.
    If you could, please post the model number off of the filter.
    Aug 2013
    Pennsylvania
    158
    Ok, so me thinks I need to fix my signature. I knew I would get it wrong a few times. Ha
    This is what I am supposed to be getting.
    MermaidMama
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Ok, now I understand the hp confusion. That sales brochure is listing the pump hp that the filter will be compatible with.
    While you are ordering the pool, consider what JasonLion said about the 2 speed option. it will save you money on pool operation.
    I will stick by what has been said about filter size. Get the biggest you can afford. 100lbs of sand will have you backwashing probably twice a month, where a 22" or 24" that holds 200- 300lbs will be more like twice a season.
    mas985's Avatar
    Pleasanton, CA
    11,741
    That is the rating for the pump only. But there is no reason why you couldn't go down to a 3/4 HP too. It will use less energy that then 1 HP. Do they have a two speed option?
    Mark
    Aug 2013
    Pennsylvania
    158
    Quote Originally Posted by Charlie_R View Post
    If I bumped up to a 22" filter, would a 1 HP pump still be sufficient?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    More than sufficient. It will work well with your pool.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I too would suggest going with the 3/4 HP pump if they don't offer a 2 speed 1 HP.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Since you are worried that a 1hp pump may not be enough for your pool, think about this: Intex 2650gph pumps are only 1/2 - 3/4 hp, and are used on 24'x52" Intex pools, and do quite well. The 2500gph 1/2hp pump that I have is almost too much for my 15'x48" pool.
    Aug 2013
    Pennsylvania
    158
    Thank you all so much!!!! You've given me lots to think about.
    Funny about dropping to 3/4 hp pump. I guess want it comes to pool pumps, bigger isn't always better. Overkill on a smaller pool. I just thought it would work "better".
    MermaidMama
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Better is relative, you would probably be ok with the bigger pump, but it would waste electricity
