Results 1 to 11 of 11
Thread: my water after using winter cover with mesh strip
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    I replaced my solid winter cover last fall with one with a foot wide mesh strip down the center. Water is very clear, but there is a good bit of fine silt on the bottom. FC was 2 with .5 CC. Spring of 2013 with solid cover my FC was 5 and I'm pretty sure CC was 0. Water was clear with no sign of dirt. Pictures are from last year and this year. Not having to worry about pumping water off solid was the main reason for going with this new cover. I also didn't have to add much water back into the pool this year. Maybe and 1.5 inches! Hope this might help people decide on which type of winter cover to buy.
    With solid cover spring of 2013
    With mesh strip cover spring of 2014
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    Re: my water after using winter cover with mesh strip
    Thanks for sharing your experience and pictures.
    Jun 2011
    Central Iowa
    105
    Thanks Linda1 for sharing these pics. Our first winter here we went with the full mesh artic armour cover as apposed to solid just so we didn't have to pump off water. We have quite a bit of silt on the bottom and has kind of been a pain and time consuming vac and backwashing.....this is only my first spring though......was thinking solid cover may not be such a bad idea after all. Your cover with the mesh strip may be the perfect in between!
    27' x 54" AG Morada RTR/19,300 gal/ 1hp-2spd Hayward Power-Flo Matrix/Hayward 256T sand filter
    Casey's Avatar
    SW PA
    10,452
    Not too bad linda! I have a solid cover. I thought I'd have a hard time with getting the water off but I didn't. I used the vac hose as a siphon. Did you have floats in your water to keep the cover off the pool water?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I use the same cover you have Linda1. I get some fine sediment also. No big deal to me, just a little vacuuming and it's good to go. I like not having to pump water off the cover 👍
    Jeff
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    Quote Originally Posted by Casey View Post
    No, no floats. The cover was pulled tight and kept above the water most of the time. When it rained hard, it would sag down some and then pop back up when the water filtered through. It seemed most of the winter it was heaped high with snow! All in all I'm pleased with how it worked. I did run the rover most of today getting up the fine dirt. Last year with the solid cover I didn't have to sweep even though I did for the heck of it.
    Casey's Avatar
    SW PA
    10,452
    I opened to a very clean and clear bottom. I think you saw it... Looks like you did really well though and thank goodness you opened because the FC was getting low!
    Stump's Avatar
    Jul 2013
    Oklahoma
    145
    Looks great Linda1 with either cover. I myself was very pleased this year when I pulled my solid cover off. This being my first opportunity after having converted to TFPC. Water was totally clear with slight sediment on floor. From the time I closed last fall till I pulled the cover last week I have been very proactive to keep all leaves and excess water from rain/snow off pool cover. The exposed top of cover was dry when my two daughters helped remove and not a single anything fell into the pool.
    24' Reprieve RD/AG/13K gal Vinyl TFP method
    Waterway Clearwater 175 sqft Cartridge
    Hayward Power-Flo Matrix 1HP Pump 2-Speed
    TF-100 Test Kit SpeedStir Borate Insta Test
    Spreading TFP to All
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    Quote Originally Posted by Stump View Post
    Looks great! It's a good feeling when you have so little work to get ready to use the pool!
    Aug 2016
    Hoopeston
    1
    Quote Originally Posted by linda1 View Post
    Where did you get this kind of cover. I have been searching for one. Thanks.
    linda1's Avatar
    Mar 2010
    Western Pa.
    298
    Google Ultimate winter pool cover. At the moment, Ebay has the lowest price.
    http://www.ebay.com/itm/ULTIMATE-Abo...-/271042984030
