Results 1 to 9 of 9
Thread: Slam nuances
    Apr 2013
    Florida
    31
    Slam nuances
    Hi everyone,
    So I've been dealing with an algae bloom for a little over a week. It's been a total mess as I have been trying to SLAM it but also was missing my CYA reagent, so I was a wild guess state. I was trying to keep the pool around 10ppm in order to kill all the algae. Long story short, someone in the house took a sample of water to the store and they sold her 10lbs of stabilizer which was put into the pool bringing the CYA up to 100! In any case, I got it back down to 60 (which I think is a good level).
    I've been adding chlorine, brushing, and even vacuumed one morning. The pool is still cloudy and seems bloomy In all honesty I've been trying to not SLAM too hard in order to allow ppl to swim in the pool but maybe that is just silly. In any case, I wanted to upload some pics to see what you all thought of where I'm at in this situation.
    It's a 10,000 gallon in ground
    FC is 4.5ppm as of this morning
    CYA was 60 yesterday
    thanks!
    10,000 Gallon In-ground pool.
    Casey's Avatar
    SW PA
    10,448
    Re: Slam nuances
    Your chlorine is too low. If you want to SLAM the pool then SLAM the pool according to the FC/CYA chart in pool school. Personally, no one gets to swim in my pool if it's needing SLAM'ed.
    30,424
    Re: Slam nuances
    SLAM doesn't work if you don't follow the procedures very precisely. It sounds like you are approaching it in a half-way manner (very common for newbies) but the problem is you get half-way results.
    Reread the SLAM process and go at it full bore and you will get your pool clear.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Slam nuances
    The reason I think your at a stand still is your FC level is not at SLAM level for your CYA level. Your SLAM level is 24 for a CYA of 60.
    You should be trying to maintain that FC level as long as you can by testing your water every couple of hours and redosing as needed.
    You can also swim in FC levels up to SLAM level as long as you can see the bottom of the pool. Safety reasons !
    Take a minute or two to review the SLAM process in Pool School. 😎
    Jeff
    Apr 2013
    Florida
    31
    Re: Slam nuances
    Thanks everyone. Guess I'll just go back to the drawing board and do it right.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Slam nuances
    If you stay on top of it it'll come around a lot faster 😎
    Jeff
    Apr 2013
    Florida
    31
    Re: Slam nuances
    When it says use bleach in the SLAM section, are we just talking about the regular bleach you get at Kmart? Typically we have these 2 gallon containers that they refill for use at the pool store. I assume it's liquid chlorine.
    30,424
    Re: Slam nuances
    Either one is fine. They will be of a different strength. Clorox is 8.25%.....the pool store stuff is likely 10% or perhaps 12.5.
    Re: Slam nuances
    Liquid Chlorine/Liquid Shock/Bleach are all the same thing, sodium hypochlorite. You can use which ever one has the best price.
