Thread: First test results
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    First test results
    FC 10
    CC .05
    PH 7.8
    CH 250
    TA 210
    CYA 20-30
    I have dialed down puck feeder should that be enough to lower FC? Water temperature 83, water crystal clear and pool is clean we vacuumed yesterday. I am converting to SWG so want to continue to use pucks to increase CYA, is this correct? Comments appreciated.
    30K gallon 20 X 40 IG vinyl built 8/2013, Hayward 1.0 hp super pump, 250,000 BTU Hayward heater, S244s Hayward Sand Filter w/side mount multi port valve, Hayward Aqua Rite Salt Chlorinator with Turbocell T-15 , Coverstar automatic pool cover with key switch, TF-100 test kit.
    30,400
    Re: First test results
    Your numbers look good and your strategy of using pucks and monitoring your subsequent CYA increase is a good one.
    You'll have to experiment with the setting on your puck dispenser but that will work just fine, too.
    Smykowski's Avatar
    Sep 2011
    3,065
    Keep track how many pucks you use so you don't overshoot. Also, you'll have to watch pH and TA. The pucks will monkey with them.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Puck strategy is good especially if you're eventually converting to salt, since they lower both the PH and TA, and you're are too high for SWG pool. If you already have the pucks to use up - go for it, I wouldn't buy more though. Too expensive in the long run.
