Thread: Charlie_R's Intex Pool Modifications
    Apr 2014
    United States
    4
    Posts moved from Adding a 2nd return to 14x42 ultra frame
    Wow Nice job with the hairdryer pipe bending Charlie! Great idea.
    I'm about to add new components to my 18' X 48" Summer Escapes and I have a couple related questions.
    Got a 2500 GPH filter/pump, Saltwater generator and a small Raypak gas heater.
    I want to hard pipe everything and add a fountain too. My plan is to bury pipe to the pool from the equipment 10' away.
    When I come up at the pool, I will have a union, and then a short piece of Spa Flex before hard pipe to the fittings, skimmer, ect.
    My main question is this.
    Can I put a low intake under the skimmer to help draw settled debris and colder water from the bottom?
    I'm wondering is cutting a low hole in unreinforced liner will be subject to higher pressure?
    With the union and flex, it would still be a foot or more from the bottom.
    Anyone know if that's an issue?
    Last edited by zea3; 05-10-2014 at 06:41 AM. Reason: move side conversation to its own thread
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Adding 2nd return to 14'x42" ultra frame
    Pete, Look for the thread I'll start for you. I'll answer there. We don't want to hi-jack threads.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    For Pete -- Second return question
    You can, I don't think it would be a problem. The piece you remove for your skimmer can be used as a reinforcing layer, glued to either the inside or out with pool rated vinyl (underwater) glue.
    Honestly, All I've done is point one of my returns towards the center of the bottom, and I get good circulation down low.
    Oh!!!
    A couple of things:
    Welcome to TFP!!
    Thank you for the compliment on the hair dryer, but it's actually not my idea. I learned it from an electrician that custom bends his PVC conduit that way.
