Thread: intex pool leg replacement
    May 2014
    ponte vedra,fla
    2
    Question intex pool leg replacement
    Do I need to drain my pool all the way to replace a couple of the vertical leg supports?
    Apr 2012
    SW Ohio
    456
    Re: intex pool leg replacement
    No
    Are the legs out of plumb or not level?
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    May 2014
    ponte vedra,fla
    2
    the legs are rusted-I have 2 new ones just don't know the best way to get them out of there-should I dig around the bottom to get more space?
    Quote Originally Posted by fast1971chevelle View Post
    No
    Casey's Avatar
    SW PA
    10,457
    I would drain the pool to be on the safe side. If you start digging in and around the support legs, you may knock it off level.
    Welcome to TFP secret squirrel! Love the user name!
