Results 1 to 9 of 9
Thread: cal hypo vs bleach
    Mar 2014
    Cincinnati OH
    31
    cal hypo vs bleach
    I thought I was getting a handle on some of this but then in reading over various topics, now I have this question:
    Is there a difference between calcium hypo and regular bleach? I thought it was the same but evidently it is not. I have an AG pool w/ a vinyl liner, can using the cal hypo hurt my pool?
    ( I think I bought cal hypo as shock last year (bag of powder) in trying to get away from the trichlor and was ok.. but maybe I am not ok.)
    Thanks
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    489
    Re: cal hypo vs bleach
    cal/hypo will increase your calcium hardness as well as chlorinate your pool
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Cal hypo is calcium hypochlorite, bleach is sodium hypochlorite. Cal hypo won't hurt your pool if you use it occasionally, but bleach accomplishes the same thing and doesn't result in a buildup of *anything*.
    When in doubt, go read Pool School => Pool Chemistry => How to Chlorinate Your Pool again :
    http://www.troublefreepool.com/conte...nate-your-pool
    As long as you're still reading and your eyes aren't totally glazed over you probably *are* getting a handle on this
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Casey's Avatar
    SW PA
    10,457
    High calcium can lead to clouding of the water and if the pH gets too high, along with the calcium from over use, it can put an unsightly scale on your liner and ruin it. Bleach, which has salt (sodium hypochlorate) adds a minimal amount of salt to the water unlike Cal Hypo, Tri Chlor and Di Chlor and is the safest of all because it doesn't have additives that will drive the water parameters out of whack.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Without knowing your pool, and fill water CH (calcium hardness) level, it is hard to suggest using Cal-Hypo. That said vinyl pools are much more forgiving in terms of scaling. I would be concerned with both clouding, and scaling if CH is very high, but without the numbers we can't say.
    One thing is certain, Bleach won't cause either one of those issues.
    Essential Links:
    Mar 2014
    Cincinnati OH
    31
    I measured my CH on Friday with my new handy dandy T100 test kit and it read at 325.
    325 is not super high but could cause excess persistent clouding when using cal hypo. I would avoid using it as much as possible. Liquid chlorine would be a better choice.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I agree with James, in time the Cal-Hypo will only increase the CH and eventually lead to higher scaling potential.
    Essential Links:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Cal-Hypo may be safe, or may even be preferred for some people with low CH fill water and high levels of water replacement (rain), if you keep an eye on the secondary effects. Having said that bleach tends to be much better for everyone in that regard, so it is our standard advice.
    Ike
