Thread: Shop Vac you use...
    Jul 2012
    CA
    240
    Shop Vac you use...
    What's a good shop vac just to drain the last 2" in my wood hot tub? Most are made for fine dust for car seats or contractors picking up drywall dust etc. I would use it only for the times I drain, around every 3 months. They offer HP, air volume, amps, not sure what I should be after, what do you guys use?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Shop Vac you use...
    Just a good sized one from a known brand. So many to choose, but staying with this you can't go wrong. Bigger the better in your case here.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    I have a Sears Craftsman wet-n-dry shop vac that will suck up water and holds about five gallons. It even has a drain valve on the side. You do have to remove the paper filter element before you use it on liquids.
    I've never used it on the pool, but it worked great to empty out a toilet before I unbolted it!
