Thread: raise PH
    Mar 2009
    Charlotte, NC
    539
    raise PH
    To raise PH use borax or soda ash or washing soda.
    Borax will add borates? which is generally a good thing (so long as the amount of borates is in the proper range)?
    You guys find washing soda at the grocery store? Its by the baking soda?
    Which material do you guys like to raise pH & why?
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: raise PH
    I would personally prefer just to aerate the pool. No other side effects except cooling the water.
    Re: raise PH
    Borax is simple to use and has minimal impact on TA, so that is generally my favorite. However, there is very little need to raise PH unless you are using trichlor tablets. If you are using trichlor you are better off using washing soda or soda ash, which are really the same chemical. They raise the TA more, which you want with trichlor.
    Washing soda and borax are both in the laundry area, while baking soda is generally in the baking isle.
    Using borax to raise PH doesn't normally add enough borates to have any effect.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: raise PH
    Quote Originally Posted by Johnny B View Post
    Thanks
    What is your TA reading? If it's around 100 or better, just aerating the pool will raise pH pretty quick. No chemicals needed. If TA and pH are both low, then washing soda will raise both. But it's sometimes hard to find. It will be in the laundry aisle with the borax, generally hidden on the very top or very bottom shelf, and maybe with the stain removers instead of with all the boxes of detergent.
    If you scroll down on poolmath you will see Effects of Adding Chemicals. It will show you what will happen to all the readings if you add X amount of Y chemical to your pool, provided you have entered all the numbers especially pool volume.
