Thread: What size heat pump do I need?
    Jun 2013
    Philadelphia, PA
    143
    We live outside of Philadelphia, PA (So you have an idea of climate.) Have an auto cover that is always on unless we're enjoying the outdoors. Does a good job of heating the water (For what it is) and keeping the heat in. Pool is about 8500 gallons.
    We've decided on a heat pump as we want to maintain temp. That decision is made, so we don't have to go there. BUT, I'd love to get an idea of what size heat pump we should get before we start talking to vendors (Who will probably beat down the door until we relent!) Been looking at Hayward, Jandy, AquaCal and Pentair. All seem to have their pluses and minuses and still doing research on which manufacturer I want. Opinions are welcome.
    But generally, I want to figure size. For our size pool, I imagine we could go with the smallest unit and be fine. But I want to oversize it as it seems this is absolutely the way to go. I don't want the unit just making it. So spending an extra $500-1000 to do it right is fine.
    So, any opinions on size?
    Leisure Pools Riv 30, 8500 gal, IG fiberglass, 200 sqft cart filter (Clean & Clear 200), Intelliflo 3HP variable speed pump, Aqua Rite SWG, auto cover, installed 5/2013
    Aquacal Superquiet 110, installed 6/2014
    TFT 100
    Nov 2011
    Moberly,MO
    1,010
    Re: What size heat pump do I need?
    You might as well get the largest btu unit. It will maintain temp easier and might not run as much as a smaller unit.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Sep 2008
    Philadelphia
    43
    All I could offer is that for houses, you don't want to oversize units as they cycle off/on too much which is inefficient and leads to peaks and valleys of temperature swings.
    Water has a different heat capacity than air so it may not be the same. Try calling a couple of mfgs and asking what size they recommend?
    25,000 gallon
    16' x32' Rectangle IG, Vinyl liner
    DE filter
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    most manufactures have a "sizing calculation" to best size the heat pump to your pool. things they will need to know would be water volume, blanket yes or no, what temperature YOU require and length of swimming season. bigger does not always means better when it comes to heat pumps.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Jun 2013
    Philadelphia, PA
    143
    Quote Originally Posted by bob22 View Post
    Bob - I had the same thought as I've been hearing over and over to oversize, but I've always known this to be bad in the house.
    I'll be calling around soon to see what I can uncover. Just wanted to go in as educated as possible. Thanks all!
    TFT 100
