Thread: Just opened the pool and. . .
    Jun 2013
    Philadelphia, PA
    143
    I've had it physically open a few times as we have an auto cover. Water is crystal clear, few leaves here and there and I've gone over it with the skimmer.
    Tonight I officially opened (My first time) and all is well. Did a full battery of tests after letting the pump run for about an hour. Beyond thrilled with the results!
    FC - 7.5
    CC - 0
    PH - 7.5
    TA - 80
    CH - 220
    CYA - 70
    Water is about 60 degrees; I let it warm up to ambient for a bit for CYA. These numbers are EXACTLY what I closed the pool at, with the exception of FC being 15 in October.
    So I guess this means it's time to swim!
    My only question - I assume this means I don't need to shock since FC survived the winter and all looks healthy, right?
    Leisure Pools Riv 30, 8500 gal, IG fiberglass, 200 sqft cart filter (Clean & Clear 200), Intelliflo 3HP variable speed pump, Aqua Rite SWG, auto cover, installed 5/2013
    Aquacal Superquiet 110, installed 6/2014
    TFT 100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    Re: Just opened the pool and. . .
    No SLAM needed. The water is clear, the CC is below .5, and I'll wager large sums of money that you won't lose anything overnight if you only lost 7.5 in 6 months. You passed.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    If the water is clear and your FC is in range for your CYA then you are good to go!
    Love TFP? Become a
    TFP Supporter!
    38,295
    Congratulations!
    Now use all your saved money to become a supporting member
    Casey's Avatar
    SW PA
    10,444
    Congratulations TroubleFreePat! I didn't have to SLAM either!!!
